Question about Dell D1028L 17" CRT Monitor
My dell D1028L monitor does not give display at start up
My moniter does not give display at start up. When I again unplug and then replug it then some times it starts giviing display and sometimes I have to unplug and replug it for 2 or 3 times.
when it starts giving display then at first its color are blur and everything is magnified but the gradually after some time it gets back in normal state.
Please answer me sir.
Slapnuts1975
  • 51 Answers
SOURCE: DELL 17' MONITOR STATUS LIGHT FLASHES, BUT WON'T COME ON
Sounds like capacitors in the power supply. Open it up and check for any swolen Caps.
Posted on Aug 14, 2008
MooMadCow
  • 38 Answers
SOURCE: Dell 2407WFP Monitor losing signal and having colored line artifacts
To your problem number 1:
I would check to see what the refresh rate is on your main monitor. Especially after waking the monitor from sleep, Windows tend to forget the refresh rate settings on secondary monitor and set it to the same as your main monitor. If your main monitor is set at 75hz or something, it could cause the secondary monitor to display the "out of range" message. When you reset the "extend my desktop to this monitor" setting, it probably resets the refresh rate to 60hz again.
This can sometime be remedied by checking to see if the monitor drivers are installed correctly. A lot of times the video card driver also gets in the way. I've had a lot of experiences with ATI drivers behaving very sporadically with multi-monitor setups, where they will consistently change to "plug-n-play monitor" and thus reverting any custom setting I have.
As to your problem #2:
I've had a fair bit of experience with this as well. The fact that the line shows the same way regardless of the monitor's own tilting orientation, means the error is probably coming from the video card signal rather than the LCD panel itself. This usually is a foresight of a nVidia card that's about to break.
I've went through many, many nVidia video cards over the years. They all inevitably break over time, probably because nVidia relies strictly on third party vendors... and to stay price competitive the third party vendors cut corners wherever they can. I always get the same horizontal line error over time as you described here.
The only way to know for sure, is to get a replacement video card, borrow one from a friend if you can, and see if the same problem still comes up. It's very possible for this to show up on only one of your two monitors. Try switching the monitor output as well, to see if the line now shows up on the other monitor instead.
Posted on Nov 04, 2008
skotkolr
  • 558 Answers
SOURCE: dell tft monitor wh 320
http://josepino.com/other_projects/?howto-repair-dell
Posted on Feb 17, 2009
najah
  • 180 Answers
SOURCE: My computer monitor will not stay on.
The problem may with the Ram inside your computer
Posted on Jul 07, 2009
  • 1684 Answers
SOURCE: Dell LCD Monor light keeps blinking green, screen
Your monitor has a bad power supply board. This happens often on LCD monitors because of the heat buildup in them. If you can solder them go to our web site at:
www.ccl-la.com/badcaps.htm We have a step by step dis-assembly and repair guide for your monitor. There are several versions of the E173FP some end in b , f, or c so be sure to check your monitor.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 27, 2009
Displaying only 2 secs
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced.
Oct 31, 2013 | BenQ Computers & Internet
My monitor will not display a picture, every now and then my screen saver is on displaying the picture as if there is nothing wrong. Help
I just hooked up the Soyo moniter to my Dell XPS M1210 laptop and it won't display. I went to the Dell manual and it said to go to Start, click Control, Panel, click Display, Click Settings but when I go to the Display part the option is not available. Help please.
Jun 17, 2011 | Soyo DYLM24D6 LCD Monitor
Dell 1503FP works, but won't start up again for a few hours
Hello there.
Seems like electronics pack up but try an old one. disconnect all the data cables from your monitor side(HDMI, DisplayPort, VGA, USB etc.) or computer side if the ones on display are built-in. Leave only the power cable. Unplug the monitor`s power cable. Press the POWER button on the front of the display and keep it pressed for 45 secs. Plug everything back and give it a try.
Good luck.
Jan 18, 2018 | Dell 1503FP 15" LCD Monitor
Dell E207WFP monitor
.Bad news.It cant be fixed.Try to take it back to the shop and get a replacement one.It might work for a few months or so but it is certainly a faulty screen.
Jul 21, 2009 | Dell D1028L 17" CRT Monitor
19 inch Dell Moniter Screen turns blank
i think may be its monitor problem or may be the wire problem that are attached with ur CPU...... change it and then see its again wrking??????
Mar 23, 2009 | Hitachi CM721F 19 in.CRT Conventional...
How to reset dell monitor d1028l
my monitor screen left said black pls ans me faster
Nov 28, 2008 | Dell D1028L 17" CRT Monitor
Speakers killed my moniter
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
May 27, 2008 | Dell Dimension 2400 PC Desktop
Monitor goes black, with ghost lines of white. unplug and replug sometimes works sometimes does'nt. it's almost like it's burn out, or blown. pounding on the top works great, it comes right back on. this...
Its more or less your monitor has gone bad.
To check the same , unplug the monitor from the computer , a slef test feature check would be displayed . Check if the monitor goes blank or shows ghost lines . If yes the monitor is bad. If you have got the system before 12 Dec 2005 its generaly covered under 3 yrs warranty.If purchased after that , it would have your system warranty
Apr 20, 2008 | Dell Dimension 3000 PC Desktop
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Dell D1028L 17" CRT Monitor Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
