Question about Samsung Dryers
Dryer will only blow cold air - Samsung Dryers
  • 7,365 Answers
Always use caution around electrical appliances
electric dryer-runs but will not heat
1.loose wiring--check terminals & wiring
2.defective thermostat--replace
3.defective centrifugal switch in motor--replace switch--check linkage in motor
4.defective timer--replace
5.open heater element--replace
gas dryer
1.faulty ignition or reset valve or thermocouple
2.thermostat
Posted on Jul 31, 2010
futureloginn
  • 734 Answers
SOURCE: DRYER BLOWING COLD AIR-NOT HEATING UP
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
  • 112 Answers
SOURCE: the dryer only blow out cold air.
I would start by checking the continuity of your thermal fuses on the unit. You will have at least one and they will be located around the heater element or ducting near the heater element. If they check out good, check to see if you have an open element.
Posted on Oct 18, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore model 76712 does not blow heat just cold air
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
Posted on Jan 22, 2009
  • 98 Answers
SOURCE: the tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Posted on Jun 07, 2009
  • 15 Answers
SOURCE: my kenmore dryer is blowing out cold air
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
Posted on Jul 20, 2009
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
My dryer is blowing cold air. I replaced the
if you hooked up yhe wires on the heating element check the thermostat it will be a oval shapef unit on housing of element and has wires going to it it may be bad.
Dec 28, 2009 | Washing Machines
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Blows cold air , it still spins, but doesnt heat up.
Is this a condenser dryer or vented?
On the condensers, if the water collector is full it will only blow cold air. Sometimes the water pumps that bring the water to the collector bottles can go and it makes the dryer think that the bottle is full, therefore it will blow cold air.
Hope this helps!
Aug 13, 2009 | Maytag Dryers
The tumble dryer is work but is only blowing cold air
Jun 07, 2009 | Zanussi TC7102W Electric Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
The dryer only blow out cold air.
When I turn the dryer on, only cold air blows out. There's no heat. I cleaned out the vents? What do you think is my problem> Thank you very much. K
Oct 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
347 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
