Question about Fisher and Paykel Washing Machines
Smartdrive 508 fills very slowly, seems to "time out". To get the cycle finnished we have advanced the cycle.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Is your complete model number GW 508? The fault with your machine is either your inlet hose filters or your water valve filters are blocked or one or both of your water valves are faulty.Turn off the water to your machine and remove the inlet hoses one by one.Check the amount of water coming out of the taps and check and clean the filters,if your inlet hoses have them, at each end of both hoses.Also where the inlet hoses connected to your machine check the filers on the water valves.If all the filters are clean and you still have the problem then the problem will be one or both of the water valves.Please reply on how you got on or for additional assistance.Hope this helps and looking forward to your reply.
Posted on Aug 01, 2010
Fisher and Paaykel Smart Drive 708 not working once filled with water.
You need to check your lid switch & out of balance switch for
corrosion and replace if faulty.
Your out of balance switch is under the big yellow motor controller
OOB switch Is where the grey plate is on this picture.
Mar 03, 2013 | Fisher and Paykel Washing Machines
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
My smartdrive 508 " beeps"
make sure yourhot and cold taps are on even when on a cold wash and see how you go
Jan 06, 2011 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel smartdrive 508 filling slowly
remove the hoses and check for any kind of clogging or restriction in the line there may also be a problem with your fill valves
Mar 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Jan 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
F&P Smartdrive 701 doesn't fill with water
There is a fill control switch. It will ususlly be up high in the machine with a small tube going to it. Pull the tube off it and blow the tube clear. Attach a piece of tube to the control and blow in that too, the switch should click. If you can, check around inside where the tube attaches to the washer to make sure there is no debris there.
Apr 28, 2009 | Washing Machines
Smartdrive 703 Model Washing Machine Leaving brown stains in clothing after some wash cycles. Stains are small and seem to be something coming through to the clothess from the slits in the drum holes. ...
if you do cold washs all the time you get a build up of sludge between the drums you need to fill it with hot water and let it soak for a few hours and then put through a high wash to rinse out,no clothes.Or you can remove the drum and wash it .hope this helps
Mar 14, 2008 | Washing Machines
Washing Machines Logo
83 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
