Question about Acer Aspire 5100-5022 Notebook
Resource conflict-pci slot in slot 3.bus 6 device 4
Hi,im having the same error message on attempted start up on an ACER 5100.iVE REOVED THE WIFI CARD AND REINSTALLED IT SEVERAL TIMES AS PER YOUR INSTRUCTIONS..NO JOY IM AFRAID..opps sorry about the cap lock.
Any further suggestions ?
    Sergeant:
    Champion:
  • 244 Answers
It's motherboard problem, you should send it for repair, nothing you can do.
sometimes it will disappear but it will come back again,
Posted on May 03, 2008
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Aug 16, 2010 | Computers & Internet
I have an Acer Aspire 5100 with Vista Home Premium on it...when starting the laptop acer 5100 it tries to start beeps...and it shows the following page of errors Bus 06, device 02 ,function 00 error...
It might be possible some kinda a BIOS corruption. Let us try this first. ASA computer starts keep on tapping F2, it will enter the BIOS setup utility, then press F9 and then F10, save the seeting and restart the computer. It should resolve the issue. But if the issue still persists, then update the BIOS. Visit the webiste mentioned below:
http://support.acer.com/drivers_download.aspx
Select the model and update the BIOS.
May 07, 2010 | Acer Aspire 5100 Notebook
Acer 5102WLMi 4GB ram windows 7 Resource Conflict PCI in slot 03
I have the same fault in Exploration of the Toshiba laptop I thought that the problem in the BIOS I have to change the BIOS of the motherboard from another device is identical to him, but did not change the message. The device to restart the work or entering the BIOS. Does not enter the Hard disk or the CD-ROM or slots of the USPI. Found that the problem in the cache on the motherboard BIOS that is stored clothing and replied to her and when I unloaded as follows.
Remove the keyboard from the device you will be proud of card Remove the card below it you will notice two signs**88
When you close with some of these points and left it for 24 hours you run the laptop did not show the message again, but this may have eliminated the possibility of a password again from the BIOS as the storage room and place one empty one.
As for this model are points of discharge under the Ram, and marked with .. And be drawn into a small rectangle and the letter written by him j
Mar 06, 2010 | Acer Aspire 5100 Notebook
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Jul 20, 2009 | Acer Aspire 5100 Notebook
Pci slot error
I have the same problem with an Aspire 5100.
I can eliminate any problems with the software, as the problem exist with the hard drive renoved.
It appears after the 'Acer' splash screen and fails as part of the POST.
After reading through various posts I suspect the broadcom wirless card or LAN has failed at board level.
I will try removing them and try again.
Will post back with results.
Jun 10, 2009 | Acer Aspire 5100 Notebook
Acer aspire laptop wont boot
y dont u dispose it off if it is a problem computer, i guess it is a generic problem of laptop need to replace motherboard or so. avail warrent if it has...
Nov 25, 2008 | Acer Aspire 5100-5033 Notebook
Acer Aspire 5100-5022 Notebook Logo
439 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
