Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony tv shuts off - Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony bravia tv keeps shutting off
in this case you tv main board is defective because this is a temperate error please replace main board
Feb 28, 2015 | Sony Bravia Kdl - 46Hx800 46 inch 3D Led...
Sony Dlp, 46" shuts off, cools off, then turns
This is probably a heat issue (assuming you aren't the one turning off the TV and aren't having regular power failures). This TV has two fans to help keep the components cool; if the temperature increases, the TV will shut down to protect those components. Also check if the ventilation slots are blocked and clean the dust off them. (When you have the TV open, you can blow out dust as well - much like dust removal for a desktop CPU.)
For replacement fans, you can go here: http://www.partstore.com/Model/Sony/Sony/KDF46E2000.aspx .
I hope this helps.
Nov 01, 2010 | Sony KDF46E2000 46" Projection HDTV
GETTING MESSAGE TV WILL SHUT OFF SOON ON Sony trinitron, then tv turns off'
More than likely someone has inadvertently set the sleep timer to ON. That will cause the set to shut off, it kindly gives you a warning that it will shut off so your TV is more than likely just fine. Usually it can be turned off using the on screen menu and the remote control.
May 30, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron Wega TV keeps shutting off and red
There are two Ic's that need replacing on the Deflection Board (D) board.. These regulate power for the High Voltage and Chopper PWM circuits. The IC location on the board are IC6501 and IC8002
Nov 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Replaced lamp in Sony Wega tv - Sony xl-2400. tv
hello make sure the lamp and the cover is fitted securely, when you've done this the tv should be ok
shaun
Nov 09, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a sony 65in projection tv. ill be watching the tv and it will just shut off by its self
There is a known issue with some Sony TV's with a leaking diods on the power supply, this causes the unit to shut off & also causes it to not power on.
Nov 08, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Tv shuts off and green light blinks 5 times and repeats 5 blinks.
Please buy new Lamp for KDF-55WF655 from Sony Accessories Store with following part number..
" A1085447A " LAMP BLOCK ASSY XL-2200U
(type model number in search box and click)
Always buy Sony original lamp for safety of your TV.
Feb 06, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony TV shut down
Sony sets have internal diagnostics. Unless the ste is 100% dead, you should see the standby light blink in a pattern of count,pause,count... Please supply that count here and I can give you details about the problem.
Dan
May 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
359 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
