Question about Casio FX-115ES Scientific Calculator
How do i enter the equation 5x-3=11+12x how do i enter quadratic equation x squared -2-35=0
  • Casio Master
  • 8,073 Answers
The variables you have at your disposal in this calculator are
A, B,C,D,X,Y,M. All of them are accessed by pressing the [ALPHA] key before the key near which is written the name of the variable. You will notice that the markings of the symbols accessed with the [ALPHA] key are of the same color as that of the [ALPHA] key.
You will notice also that there are two = signs.
The one at the bottom right executes the command line. By pressing it you find the result of the expression just entered.
The other = sign is marked on the body of the calculator with the same color as the [ALPHA] key. It is located at the top left of the keyboard (excluding the row with SHIFT, MODE, the navigation buttons)
Example to enter X^2-2X-35=0 (not your expression)
Direct access physical keys are in [ ],
[ALPHA] (X) [X to power 2] [ - ] [2] [ * ][ALPHA][(X) [ - ] [3][5] [ALPHA] (=) [0]
Usually when you enter such an expression it is with the intention of solving it for X. By default X is taken to be the UNKNOWN. You will be prompted to enter the value assigned to any other letter symbol (Y, A,B,C,D).
So, if you want to use the Solve function, you press [SHIFT] [CALC] and the calculator will ask you a question: "Solve for X?" , and you press the = sign at the bottom right.
Then you will be prompted for any other non-X letter.
Posted on Aug 21, 2010
2x squared equals 4x plus 30
Plugging the coefficients 2, -2, and -30 into the quadratic equation produces -3 and 5.
If this is homework, be sure to show your work.
Mar 27, 2013 | Office Equipment & Supplies
How to solve quadratic equation in fx-100ms
See if it has an equation mode, and select quadratic equations. If it has a SOLVE feature, enter equation, provide a guess and solve.
Feb 26, 2013 | Casio Office Equipment & Supplies
How do i factor
This calculator is unable to factor a polynomial expression.
In general there are a few factoring methods
  1. Factor by grouping terms
  2. Factor by completing the square (quadratic polynomial)
  3. Factor by finding two integers such their sum is equal to the coefficient of the middle term, and their product is equal to the third (constant term). This is valid for a quadratic polynomial where the leading coefficient (of the x^2 term) is equal to 1. X^2+SX+P
A cubic equation can be solved algebraically, although two solutions may be complex. Use the Cardano formulas. A quartic equation can be solved by the formulas for the quadratic equation, if you transform the quartic equation to look like A(X^2)^2 + B(X^2) +C=0
Jul 31, 2012 | Casio FX-115ES Scientific Calculator
Write each quadratic equation in standard form. . identify the values of a,b,and c. . ...
  • Solve (x + 2)(x + 3) = 12.
    It is very common for students to see this type of problem, and say:
      "Cool! It's already factored! So I'll set the factors equal to 12 and
      solve to get x = 10 and x = 9. That was easy!"
    Yeah, it was easy; it was also (warning!) wrong. Besides the fact that (10 + 2)(9 + 3) does not equal 12, you should never forget that you must have "(quadratic) equals (zero)" before you can solve.
    So, tempting though it may be, I cannot set each of the factors above equal to the other side of the equation and "solve". Instead, I first have to multiply out and simplify the left-hand side, then subtract the 12 over to the left-hand side, and re-factor. Only then can I solve.
      (x + 2)(x + 3) = 12
      x2 + 5x + 6 = 12
      x2 + 5x - 6 = 0
      (x + 6)(x - 1) = 0
      x + 6 = 0 or x - 1 = 0
      x = -6 or x = 1
    Then the solution to (x + 2)(x + 3) = 12 is x = -6, 1
Jul 17, 2011 | H. B. Enterprises Quadratic Solver
How to factor 5x^2-3x-10 ?
This equation doesn't have whole number factors so you have to solve it by completing the square or using the quadratic equation. I used the quadratic equation and got the following answers.
[3 + sqrt(209)]/10 and [3 - sqrt(209)]/10
I hope this helps you out.
Jul 05, 2011 | SoftMath Algebrator - Algebra Homework...
Can you factor quadratic equations on the Casio fx-11ES? If yes how?
Press MODE 5 to bring up the equation types. Press 3 for the quadratic. Enter the three coefficients. Press = to see the first root. If the display shows x1 then press down to see the other other root. If the display only shows x then that's a double root. Given the two roots x1 and x2, the factors of the quadratic are (x-x1) and (x-x2).
Refer to "Equation Calculations" on page E-55 of the manual and examples #094 and #095 in the appendix for examples of solving quadratic equations. If the you need the manual and/or appendix, you can download them from
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
May 11, 2011 | Casio FX-115ES Scientific Calculator
2x^2-19x+22
I'm assumeing the problem is 2x^2 - 19x+22 = 0, solve for x.
I don't see any easy to factor this so I'll either need to complete the square or use the quadratic equation.
Using the quadratic equation, where A = 2, B = -19, and C = 22
x = [-(-19) +/- squareroot( 19^2 - 4*2*22)] / (2*2) =
(19 +/- squareroot(185))/4 =
8.150367 or 1.349632
Feb 01, 2011 | SoftMath Algebrator - Algebra Homework...
I am trying to solve a quadratic function using the calculator but i dont seem to be able to do so. For example if i had a question like 5x^2 + 15x +3, how would i use the sharp el-w535 to find the x...
This expression 5x^2+15x+3 is not an equation, therefore it can have any value depending on the value of x. You have to make it an equation before looking for the particular value of x that satisfy your equation 5x^2+15x+3 =0
This calculator cannot solve equations because it does not have an equation solver.
Dec 15, 2010 | Sharp ELW535 Calculator
HOW DO YOU ENTER r2 ON A TEXAS INSTRUMENT CALCULATOR?
No need to enter R squared. If it has meaning it will display in the stats variables screen ( 2nd F7 ).
Hope it helps.
Nov 12, 2008 | Texas Instruments TI-89 Calculator
Casio FX-115ES Scientific Calculator Logo
391 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
