Question about Microsoft Windows XP Professional for PC
Hi, im having problem with my windows usb it cannot be detected by my windows xp.. in the device manager the mass storage device is marked (x) on it. what would i do to make this functional on my computer? pls help me with this problem. mhomz..
  • 496 Answers
First of all try changing the usb port you are using I am sure that there will be more than one usb ports in your PC. After this try using another similar USB device.
I mean if you are trying to plug in a Flash drive use a different one or If you are trying to connect an external Hard Disk (as it is obvious from the mass storage device marked with an x as you have pointed out). Try using a different External Hard Disk that you may borrow from someone checks will help you locate the problem. The reason why your USB device is not being detected by your PC must be the driver of the USB drive is out dated. Check the version of the USB Is it 2.0? or the driver might have been corrupt.
You can download USB Mass storage driver from the following site. You can search for USB drivers on other sites also.
http://download.cnet.com/windows/usb-drivers/
Best of Luck!
Posted on Jul 31, 2010
I have 1 note book LG X120 with windows 7. when im trying to install Windows XP proffessional through a USB CD ROM its showing the following Message * To specify additional SCSI adapters, CD-ROM...
Hi lionking2022!
Since this is a USB CD_ROM, you need change some settings in the bios for it to be detected and the system will actually boot from it.
1. You enter your BIOS
2. Look for the tab that will contain IDE settings
3. Change it to AHCI
4. Save and Exit
You may know try to boot from cd-rom and install your windows xp.
After the setup or installation is finished don't forget to changed it back to SATA or whatever the setting was.
Hope this will help.
Thank you for using Fixya,
avf110686
Mar 24, 2011 | AGPtek USB External CDROM Drive For LG...
Hi I am running Window Me and my freecom external won't work
unplug its usb cable and plug it into a different usb port
Mar 30, 2010 | Computers & Internet
The external hard disc is not detected by the computer
Please Check in Device Manager
To Open Device Manager, Right Click My Computer icon and click on Properties. No click Tab called Device Manager. In open window please look at last entries that may be " Universal Storage Controller. and IS there any Entry Looks like MASS STORAGE Device with Yellow Mark on. IF yes then right click on that click un install and re- plug HDD.
Also please check whether LED is blinking or not in HDD. if not then try check by replacing USB cable.
Mar 16, 2010 | Computers & Internet
Sandisk is not being recognized on my computer
SOLUTION 1 - Verify if minimum system requirement is met.
SanDisk card readers support Windows Vista, Windows XP SP2 and Windows 2000 SP4.
For MAC users, see
Troubleshooting USB device on MAC
SOLUTION 2 - Verify the reader's status under Device Manager.
STEP 1 - Connect the reader to the PC
NOTE: It is recommended that you plug your card reader to the back USB port on your PC to ensure that there is enough power from the USB port for the card reader to be detected properly.
STEP 2 - Check under Device Manager
1. Right-click My Computer.
2. Select Manage.
3. On the left pane, click Device Manager.
NOTE: The card reader will appear in two places: Disk Drives and Universal Serial Bus controls as USB Mass Storage. If there is a yellow exclamation point (!) or question mark (?) next to the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action, and then click Scan for hardware changes.
STEP 4 - Verify if the reader is detected
1. Double-click My Computer.
2. Look for the card reader under Devices with removable storage.
SOLUTION 3 - Try other USB ports.
A yellow exclamation point (!) under Device Manager usually means that the device is not receiving enough power. If the reader is not receiving ample amount of power from the USB port, it may not function properly.
SOLUTION 4 - Change the drive letters
NOTE: The SDDR-89 reader should show 4 drive letters under My Computer.
Mar 01, 2010 | SanDisk Sansa m250 MP3 Player
Pen drive
Hi.
If you delete it in device manager and re-detect it, does it change? If you can see it in the taskbar, can you use the eject device icon to eject it, then remove and re-insert the drive?
Finally, try it on someone elses computer and see what result you get.
Mark
Nov 04, 2008 | Electronics - Others
Can't get the software to detect the device
should be no compatibility problem.. not with xp... but you can check two different things... first check the "safely remove hardware" icon usually beside the time in the system tray. when you click on it once, it should say safely remove usb mass storage device drive *: (star representing drive letter), if no letter comes up then no drive letter is assigned and will have to go thru drive letter assignment.
the next thing would be in device manager in system properties... it should be recognized as usb mass storage device and disappear if you unplug your device. if not then the driver may need updating through microsoft
i would call Oly tech support so they can walk you thru the getting your device to work properly
Sep 15, 2008 | Olympus DS-2300 Digital Voice Recorder
Mass storage device not working
transend pendrive not recognized
Feb 28, 2008 | Electronics - Others
Iomega portable hard drive
Please check in device manager that storage mass device is not showing yellow mark if it is please first remove any storage device showing yellow mark in usb devices in device manager >
You wil find device manager in windows 2000/xp in control panel >administrative tools>computer management ..then click on device manager
Second thing is please remove/uninstall any storage device information from device manager
Restart the pc and then go to device manager and see there should be no entry of storage device in usb root devices .After this fix your usb device and it will work definately
Regards
Balisonu79
Feb 13, 2008 | Iomega Zip 100MB (31714) External ZIP...
Microsoft Windows XP Professional for PC Logo
122 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
