Question about Whirlpool Duet GHW9150P Front Load Washer
Error code when i'm washing on the whitest whites mode an error code ( F 20) comes up and the washer has stopped not letting me continue washing
    President:
  • 1,382 Answers
The reason for "F 20" is that while there is "NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED." If after 30 seconds not minimum 0.1l of water entered or maximum fill time of 13 minutes is exceeded, the valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display.
The possible fix for this problem is:
If there is no water in the unit: Make sure that both valves at the water source(s) are turned on all the way.
Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
Verify inlet valve operation.
If there is water in the unit: Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Unplug washer or disconnect power.
2. Verify there is not a siphon problem.
3. Verify wire harness connections to inlet valves, pressure switch, flow meter, and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Thank you
Posted on Jul 31, 2010
I'm working on a kenmore 11046472501   Washer
Did you get an error code? Also, take a wet-dry vac and **** the drain line. Sometimes there will be a blockage there as well. Have you checked the door switch for continuity?
Nov 03, 2012 | Washing Machines
Whirlpool Duet washer - 4 years old- Error message F 24. It happened first during a "whitest white loads." Was able to re-start it and that load went through. Now it's happening all the time. ...
F24 Water temp sensor error. Failed sensor or heater. Remove your bottom panel and look for your tech sheet. It will give diagnostics and error codes. Manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 12, 2010 | Whirlpool Washing Machines
Washer stops and F 51 flashs
Hello, It is a rotor position sensor code. The control is no longer receiving a signal from the motor. It can be a failed sensor or control, but usually it is a bad connection where the wires plug on to the sensor.
Thanks
Jun 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio: During a white load the machine stops at 38 min
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
May 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
When cleaning the washing machine it stopped and the RL came on. What is RL?
RL means at the start of the CLEANING WASHER cycle a load isdetected inside the drum.
Try removing clothes from drum and start the cycle again.
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Dec 29, 2009 | Amana Washing Machines
Musty smell
This problem is caused because the water does not get totally pumped out of the outer tub and sits in the bottom of the tub and in the front seals. Eventually a mildew type scum develops and causes the washer to stink and also impart the odor to clothes. Even though front loaders do use less water and energy, all of them have essentially the same design and therefore all will eventually develop this problem.
Run a load with just bleach (about 1 cup) and white vinegar (about 1 1/2 cups) poured directly into the washer with hot water and it seemed to help, but this does need to be repeated about once a month or so...
but with your wife's Asthma tho you could try
Typically the cause is the machine itself, but occasionally the water being used in the washer can be the source of the problem. If the smell resembles rotten eggs, you may need a water filtration system installed. After you eliminate any other possibilities, you can begin the treatment process. Create a mixture of baking soda and vinegar. Add 1/2 cup of baking soda to 2 cups of white distilled vinegar. 3Begin a wash cycle using the machine’s hottest setting. As the water rises, add the baking soda and vinegar mixture. Let the washing machine complete a full cycle. If you notice any residue that has been loosened, use a cloth to wipe the surface clean. Run a cold water cycle to complete the process. You should immediately notice that the smell has been neutralized.
Feb 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What is kenmore he4t button sequence for
If the washer does not come equipped with a "Clean" cycle, then run the washer on it's hottest setting. "Sanitary" or "Whitest Whites" will do. Hope this helps.
Feb 04, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Help anyone. Machine will only start for the first minute
F/05 Water Temperature Sensor Error If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed. Check the Water Temperature Sensor, Heating Element and Element Relay Check connections to the Sensor, Heating Element and Relay Hope this is helpful.
Sep 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loading washer purchased in 2004, beeps and displays F9 code during whitest white cycle or heavyduty cycle when washing towels, this provokes unusual delays, frustration and ineff
Boyz, your machine is draining too slowly. When it initiates a drain cycle, the water level switch is sensing the water level is still too high after 60 seconds so the computer stops and generates this fault code. Here are the things to check; * Check the drain hose and make sure it is not plugged or inked. * Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) * Check/Clean Drain Pump Filter of foreign objects * Check for Drain Pump Failure * Check the Inlet Valve for proper shut off * Check the Pressure switch for proper operation
Aug 01, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
43 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
