Question about GE Refrigerators
Gr Side-by-side refrigerator freezer makes noise when door close
Our GE model TFX24R refrigerator freezer makes a grinding noise when the door is closed, but stops immediately when door is opened even a crack. The noise does not start until the door is completely closed, and is not activated by pushing the switch to turn the light off in freezer.
  • GE Master
  • 17,130 Answers
It is possible that the hinges of your freezer has moved and shifted the alignment. So first of all use a WD40 cleaner to spray into the hinges and the areas around it. Now move the hinges violently for some time and check if has lessened. If so repeat the spraying. See if here is dirt accumulated along the hinges if the door is not moving parallel just push the end up a little . You must be able to get the hinge to shut properly by this correction. Hope you try . Good day
Posted on Jul 31, 2010
Re: GE Model TFX24R Side-by-Side 23.6 Cu Ft Refrigerator The refrigerator door needs to be raised to correct closure, it is visibly low and stands open. However, I have not been able to figure out how...
the cam must have broke and this is why the door fell,the cams are made of plastic,part number WR2X4901 and it's around 15 dollars,there's a couple of shims that are there too but they should still be good,
May 14, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
GE (Side x DSide) Adora: closing fridge door causes the freezer door to open
That will happen if you close the door too quickly or make sure the freezer door gasket is sealing properly.
Nov 20, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Freezer door does not close properly
inspect the seal all the way around the door. check to make sure that it is not in a bind when you open and close the door. if it is you can try a little wd40 or silicone spray on the gasket and frame of the refrigerator where the gasket meets the frame. this will help it slide accros the frame better.
if the gasket is bound up and out of shape, you can heat it up with very hot water to straighten it.
make sure that you keep the gasket and the door facing clean. spillage from the use of the refrigerator/freezer can cause the gasket to stick especially at the bottom.
Jul 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
Our side by side freezer door opens slightly
That is a common occurrance for side by side refrigerators. Closing the fresh food door is like having your car windows closed and closing the door. You can feel the air pressure on your ears. In the refrigerator, the air passes through the duct and into the freezer pushing the door open. The magnet on the door gasket should keep it closed. But it may be the freezer door needs the hinges adjusted to the door seats better when closed. Take the plastic cover off the top hinge and you can loosen the screws (don't take them out) and adjust the door slightly (so it looks even between both doors) and tighten the screws up. The top of the door should be level with the top of the unit, and the gap between the doors even the whole way down.
Jan 03, 2010 | GE Refrigerators
Suddenly our GE side-by-side fridge door doesn't shut
Check the bottom of the freezer door at the hinge to see how it is suppose to look and work, assuming the freezer door still works right. Then look at the ref. door and compare.
Sounds like something is broken or damaged. Usually there is a white tefflon washer which is beveled to allow the weight of the door to help it close. Check with an appliance parts store, you may be able to buy just the washer or the whole hinge assembly may come in a package.
Jan 25, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Water dispenser lg gr-602tvpf
I also have the same problem. No water but the ice maker works.
Jan 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
220 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
