Question about Philips 50PFP5332D 50 in. Plasma Television
Plugged in no power
The TV won't turn on. No blue light. No booting noises.
Phillips 50 PFP5332D 50
  • Philips Master
  • 12,061 Answers
Www.scribd.com/.../Philips-Training-Manual-TV-Plasma-Display-Panel-Chasis-FTV1-9 -
www.scribd.com/.../Philips-DPTV400-TV-Projection-Training-Manual
Above is a service training manual, to give you an idea of how it all works. To do ANY work, one MUST obtain a Service manual for your exact make and model.
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, a Philips, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand.
Posted on Jul 31, 2010
My 50 inch Phillips tv model #50PL9220D/37 wont turn on? blue power light is just flashing ? what could be the problem?
Hello more than likely the lamp has gone bad. On that set you have to remove the back cover to check the lamp to see if it has broken. the picture gives you an idea and some instructions on how to change it. tks7bef3142-61c4-4329-b27d-2507769a830c.jpg
Nov 04, 2013 | Philips 50PL9126D/37B 50" DLP TV
My Phillips 52" LCD TV won't turn on...it is just
it possibly you have shorted power supply board or inverter board that cause of clicking sounds..
try to unplug the inverter board then try again if the indicator lit in blue you have shorted inverter board that need to be replace.
Nov 06, 2012 | Televison & Video
Problem with a Phillips 32 in TV green light blinking
There is some problem with main board. Seek tech support
Jun 02, 2012 | Philips Televison & Video
I have a 50" phillips
hi need more information on the fault, thanks
shaun
Apr 16, 2017 | Televison & Video
TV wont turn on????
Some models may have a small little hole in the back to reset the TV if not I believe it may burn out on you.
Have it chec by your localTV repair man
Jun 29, 2010 | Philips 50PL9126D/37B 50" DLP TV
My tv us fkashing blue light 3xs then resets no
I suspect that in this case your power board has a fault and will need technical intervention. NOT A DIY
But first try this, its a hard reset.
Turn unit off, unplug and leave overnight. Then re plug and turn on, if problem persists its a trip to the service shop.
Please rate my help++++Thanks for using FIXYA
Nov 22, 2009 | HP Pavilion MD5020N 50" DLP HDTV
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
50 inch phillips hdtv model:50pl9126d/37, no picture...
Unplug for one hour then plug back in---worked for me--computer resets
Mar 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My Toshiba 50 inch projection screen TV isnt displaying
If you are capable of some basic troubleshooting you can determine what's wrong but you won't likely be able to fix it yourself. If you remove the TV's back panel, you can locate three plug connectors for the convergence correction yokes. You pull the red, blue, and green connectors and then plug the TV back in and hit the power button. If the TV comes on, its a failure of the convergence output ICs and will cost $350-450 if you call in a service company.
michtech
Feb 14, 2009 | Toshiba TP50G60 50" Rear Projection...
Philips 50PFP5332D 50 in. Plasma Television Logo
272 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
