Question about Fujitsu P42VHA30WS Television
Get an error message
Getting an error message condition 1?
    President:
  • 1,932 Answers
Condition 1 error denotes there is some defect in the fan inside.
You cannot deal with this problem.
Please remove the plug from receptacle and contact you dealer
Thanx
Posted on Jul 31, 2010
I have a fugistu 50inch plasma 2007 when turned one it says error message condition one
Error condition 1 is a faulty Fan. On these units if one fan is faulty then the sensor will shut the screen down as a protection.
Mar 02, 2018 | Televison & Video
What does the E1 error message mean?
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Jul 23, 2011 | Haier HWR08XC7 Air Conditioner
I;m getting an E1 error message and not sure what that means or how to fix asap!
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
heatman101
Jan 21, 2011 | Heating & Cooling
My Fujitzu gets: Error Mesage Condition 2 !
When you get the Error message conditon 2 ,It denotes that the internal components are HOT.
Please remove the power cord from the receptacle and allow it to cool sufficeintly.
After cooling sufficiently power it ON,If you get the Error message again then remove the power cord and contact your dealer.
Thanx
Jun 06, 2010 | Fujitsu Plasmavision 42" TV
Error Message: Condition 1
a repair of this unit is possible.
Regards
May 12, 2010 | Fujitsu Plasmavision PDS-4214 42 in....
My 1-var stats button is not working it says the
You will have to report faithfully the message returned, you cannot use your interpretation of the message. Error messages are codified. Each one will correspond to very particular error conditions. I did check the manual for all possible error messages and there is none that states wrong info.
My hunch is that there are errors in your data, but I can't say what type of error: I do not have the actual message returned. Verify you data, item by item, and try again.
To make sure that the calculator is well configured to do statistics
  1. Press [STAT][5:SetUpEditor][ENTER]
  2. Press [2nd][0] (CATALOG) and press [PRGM] (C) to jump to the first command starting with C.
  3. Scroll down to [ClrAllListsts] and press [ENTER]
  4. Calculator replies Done
Restart your statistical data entry.
Hope it helps.
Thank you for rating this solution
Dec 11, 2009 | Texas Instruments TI-83 Plus Calculator
RICOH FT5832 ERROR CODE E-5 47
With the machine on, press clear modes(yellow button), 107, and then hold down clear/stop (red button). Enter 5810 then # key then 1 #. Turn off the main power then power back on. This code is a fuser lamp on condition. It should clear. If not reseat the fuser unit (gets hot), clear using above procedure and try again.
Apr 08, 2009 | Ricoh FT5832 Copier
Error message 388
Hi! Error 388 means the local machine has originated a fax session and detected a remote fax machine but has been unable to detect any T30 frames.
If the machine is in V.17 mode, it is likely the connection has been interrupted. In V.34 mode is also possible for this error to occur due to compatibility problems with certain machines and/or line conditions.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. Disable V.34 on the local machine and attempt the transmission using the V.17 mode. ( See error 227 for changing to a slower speed or disabling V.34 .)
Use the link below-
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1153695&prodTypeId=18972&prodSeriesId=1153695&objectID=buu02549
Jan 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
Blue ice air conditioning unit (portable) not heating erro message E8
Every co. has their own logic control and error codes , however in my knowledge it may be of :
1. motor connection
2. Defrost sensor error-chk condensor/ evap. coil
provide some more clue to explore option of trip.
Jan 03, 2008 | Heating & Cooling
Fujitsu P42VHA30WS Television Logo
67 people viewed this question
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
