Question about V, Inc. Dump Trailer Pump 12v Dc Single Acting Hydraulic Pump
Dump trailer wont dump
I have replaced the control unit,and now had the electrical motor that drives the pump rebuilt. Still when you hit the lift button nothing happens, new battery,good connections, definately power to the celenoid,New celenoid as well,
could the problem be in the wire that runs to the top of the hydraulic motor just ahead of electrical motor that drives it ?
seems to have no signal to engage new electric motor,
My 2ooo Chevy dump truck dump body will not go up
no oil in reservoir
electronic control wires problem to valve body
failed seal on ram piston by passing oil
faulty over load pressure valve releasing at too low a pressure
pump not working --electric motor , motor contacts or if mechanical , no drive action on pump shaft
NOTE-- SAFETY DENOTES THAT YOU PLACE A SUBSTANTIAL PROP UNDER A RAISED BODY AS IT DROPS AND ACTS LIKE SCISSORS ON ANY THING BETWEEN IT AND THE CHASSIS
Apr 27, 2018 | Cars & Trucks
Three point hitch. want lift rebuilt pump on side
Is the control valve leaking internally? Might need new o rings or replaced.
Oct 15, 2014 | Cars & Trucks
How do I get my 1998 Chevy 1 Ton dump to lift a full load of materials?
Well, if you are not leaking fluid everywhere it can only be 2 things, either the cylinder is not holding pressure internally or the pump is not making enough pressure. I would start by getting the cylinder rebuilt, this is common and usually cheaper than having the pump rebuilt.
Sep 28, 2014 | Cars & Trucks
97 acura cl gas gage not working
looks like your fuel sender and pump are in your tank. run it out of gas or drain it , drop the tank replace fuel pump and filter and sender unit at once. check for rotton hoses, leaks , old gasket should be replaced.
after market parts that meet OEM are ok. don't use rebuilt stuff
Oct 28, 2013 | Sew Eurodrive Motor Drive Unit Drive...
Bobcat 533 tilt and lift not working
The hydroloic pump that operates the lift is failing. The drive operates on a separate pump so that pump is good. Find the pump that the lift rams hoses go to. That's the one you need to examine. Check all connections. Electrical, hydrolic lines, vacume hoses... everything. If all that checks out, then you need to have the pump rebuilt or replaced
Nov 10, 2017 | Cars & Trucks
How do I prime the hydraulic pump om a dump trailer.
I've always just cycled a hydraulic system full open of the piston and then full closed. The air works it's way out on its own.
Feb 16, 2013 | V, Inc. Dump Trailer Pump 12v Dc Double...
Have a 7x14 bray dump trailer dumps 3/4's then runs out of fluid. to fully dump i have to add fluid then as the box lowers down it pushes the extra fluid on to the ground?
When the dumping piston lowers, there should be fluid being taken into the other side of the piston from the return hose. The fluid level in the reservoir should not change. Has the hose routing been changed from original design?
Gary
Jul 26, 2011 | V, Inc. Dump Trailer Pump 12v Dc Double...
GE Model WCVH6800J Error Code 04. I do not have list of codes for this model, so I need translation.
TROUBLESHOOTING CHART
Codes Description Action
22,23 Fill problems
• Ensure manual water valves are fully open.
• Check if water strainers on solenoid valve assembly are clogged.
• Check for obstructions inside inlet water hoses.
• Ensure solenoid valves do not leak when the valves are de-energized and the washer is powered down. • Measure coil resistance for both valves; if outside range (1000-1250 ohms at room temp.), replace solenoid valve
assembly.
IF ABOVE STEPS DO NOT CLEAR THE PROBLEM, OR FOR ERROR CODE 23:
• Replace solenoid valve assembly.
30, 31 Drain problems
• Ensure pump strainer is clean and free of debris.
• Check for obstruction inside the drain hose.
• Check pump impeller blades and bearing; if evidence of blade damage or seized bearings are present, replace the pump.
• Check electrical connections at the pump motor and harness.
• Measure pump motor resistance; if outside range (9-14 ohms at room temp.), replace the pump.
38,39 Dispenser problems
• Check for obstruction in dispenser mechanism and linkages.
• Check electrical connections at dispenser motor feedback switch and in the harness.
IF ABOVE STEPS DO NOT CLEAR THE PROBLEM:
• Replace dispenser motor assembly.
42,45, 49 Motor Drive operation above design limits
• Ensure all 4 shipping bolts have been properly removed.
• Remove all foreign objects that may be lodged between inner and outer basket.
• Look for signs of seized bearing(s) on basket and drum motor, replace components as necessary.
• Inspect condition and mounting of door gasket, replace and re-mount as necessary.
• Ensure inner basket (drum) can rotate freely.
• Replace motor drive or drum motor.
43,4A, 4B,4C, Motor Drive internal problems
4E,4F, 50,52,
53,54
• Measure AC outlet voltage, ensure correct range (102V to 132V AC).
• Check electrical connections at the drum motor, motor drive.
• Check harness integrity between main control and motor drive.
• Unplug the unit, wait 30 seconds, restart the unit.
• If the fault persists and re-appears -replace the motor drive.
problems
57,58,71 Main Control internal problems
• Unplug the unit, wait 30 seconds, re-start the unit.
• If the fault persists and re-appears -replace the main control.
60,61,63,64, DOOR LOCK assembly problems
• Check integrity of wiring and connections between main control and DOOR LOCK mechanism.
• Investigate DOOR-LOCK mechanism, check door microswitch operation, lock and unlock solenoid continuity, contact integrity;
replace DOOR LOCK mechanism if necessary.
• Replace the main control.
65 Water Level Sensor problems
• Check integrity of wiring and connections between main control and Water Level Sensor.
• Check integrity of Water Level Sensor, replace if necessary.
66,67 Water Temperature Sensor problems
• Check integrity of wiring and connections between main control and HeaterfThermistor Assembly.
• Using ohmmeter, measure Thermistor resistance; if outside expected range, replace HeaterfThermistor Assembly.
70 "Stuck" key
• Press each key. There should be mechanical "click" feedback with every press.
• Enter Service mode, use 104 test to check key operation. Press every key. Every keypress should generate audible
"beep." Press "Power" key last to avoid premature exit from t04 test.
• Separate control and control housing from the front panel; clean and remove all foreign matter and debris from keys,
front panel and control housing, re-assemble. Ensure all keys can be operated freely without "sticking."
IF ABOVE STEP DOES NOT CLEAR THE PROBLEM:
62 System Contact Failure
• Check integrity of wiring and connections, look for insulation breakdown and short circuit conditions on the harness, replace
harness if necessary.
• Check integrity and electrical connections of all loads (heater, pump, pressure switch, door lock, solenoid valves,
dispenser motor), replace respective components if necessary.
Jun 23, 2011 | General Electric WCVH6800J Front Load...
Dryer does not start up when the start button is pressed. It makes a click like a relay is closing but no power to the drum motor, or electric heat. unit interior lights up, and controls light up. When...
Your belt is likely broken. Pop the top (held down by spring clips) to inspect. If you see it - try to lift it. If you can not lift it it is ok. If not ok, remove the front cover for complete access to the drive.
Dec 29, 2009 | Kenmore HE2 Plus Front Load Washer
My 1978 140 evinrude electric trim tilt motor working but wont lift or lower happend suddenly after it lifted.maybe the pump?
First make sure you are not in transit mode. Some outboards have a lever which keeps the motor tilted for trailering. You should have a fuse for the tilt motor, check that. If the pump is turning and it sounds like it is whining you are pushing air and either lost your hydraulic fluid or have an air bubble in the system. Check your fluid reservoir.
Jun 06, 2009 | Boating
V, Inc. Dump Trailer Pump 12v Dc Single Acting Hydraulic Pump Logo
348 people viewed this question
Top V, Inc. Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a V, Inc. Plumbing Expert? Answer questions, earn points and help others
