I have an emachine with Windows 7 and cannot install my xerox 6180N PS or 6180DN PS. It looks like it installs, but when I test print I get a message that there is a windows error and does not recognize printer. HELP
  • 12,061 Answers
You MUST install ALL software and Drivers, as Administrator. It MUST be a Win 7 Driver, OR you MUST install incompatibility mode for Win XP SP2. as Administrator, again
IF using a 64 bit version Windows, you must disable digital signature signing... Press F8 at bootup and choose from menu, right at bottom.
Posted on Jul 31, 2010
How do you print two sided on xerox 6180 phaser
I expect you have to put the paper in the other side up. however if you do you could spoil the first side as it will melt the wax again when it's fusing the second side!
Good Luck.
Jul 31, 2014 | Xerox Phaser 6180N Laser Printer
Phaser 6010 not printing windows 7 64 bit
If this printer was installed from the network its possible the windows 8 driver was incorrectly loaded on the server or from the disk. Happens a lot. If you have access to the change driver tab under printer properties, change it to a windows seven driver. Those can be found at www.xerox.com, clicking support and drivers and then typing in the model number and clicking on driver/downloads. You can at this point either let the automated Install handle it, or cancel after it has extracted to c:\xerox and manually change the driver as mentioned above. PS and pcl make no difference, however I highly do Not recommend the global driver for this little guy.
Sep 06, 2013 | Xerox Printer Division Xerox Phaser 6010/N...
Hello: I removed all installed printers from the uninstall list in control panel the other evening. Then I deleted two icons from the devices and printers window but they sometimes reappear. This time, I...
Hi Edward
The automatic reappear printer problem its come when you are connect to two and three computer in same network, when the network on the automatic search the printer in network if you install that printer in any other PC so automatic the printer is add in your printer list.
For installing the printer not nee to delete the all printer, put the installation CD in Rom and click the setup.exe
Cheer
Jul 11, 2011 | Xerox Phaser 6180N Laser Printer
My printer xerox phaser 8560mfp is printing landscape 1/2 page instead of a full size portrait from a pdf file. How do I get that fixed? Thanks!
You need the new driver. Goto the Xerox website and download the latest driver and save it on your C: drive. Goto Devices and Printers and remove your existing Xerox 8560MFP. Reboot your computer and go back to this screen and click on "add a printer". When you get to the screen "Install the printer driver" you will see Xerox 8560MFP PS highlighted DO NOT CHOOSE THIS! (you will simply be installing the same driver from Windows 7 back). Instead, Click on "Have Disk... and navigate to where you saved the driver. Choose that one and finish the install.
May 20, 2011 | Xerox Phaser 8560MFP Laser Printer
Hi and thanks - I have a three-computer home-office network. One computer has W7 and the other two have XP Pro. My Phaser 6180 installs just fine on my W7, but on my XP computers, after installing the...
Go into your computers control panel, under devices and printers locate your printer and right click, go into hardware and drivers and click update driver and let the computer search on it's own.
May 19, 2011 | Xerox Phaser 6180N Laser Printer
I am not able to print from my laptop ( HP with Windows 7) on a Xerox Phaser 8560 that is on our network. I can see the printer, and it installs, but it will not print. Microsoft word says it can not...
This sort of problem can be the result of having too many printers installed on one machine. Although you can see the networked printer, the computer actually thinks it cant hence it sees no problem.Try removing the other printers. did you install from the original cd? If you uninstall it (That means dont just right click in printers and hit delete) but uninstall through programs,xerox if there is one. Download the latest Win7 driver from xerox and install again. finally if the problem is still there then compare your win7 installation with one of the others. If all fails then the only way you are going to get it to work is reinstall windows.
Apr 26, 2011 | Xerox Phaser 8560DN Laser Printer
Hi, my Xerox phaser 6110 is installed on a Windows XP computer and i'm trying to share it with another Windows 7 computer on the same network. Unfortunately, the drivers i downloaded for windows 7 will...
follow this simple steps:
  1. Share you printer
  2. Go to your Win 7 PC
  3. Find your Win XP PC on network
  4. Click to see shared devices
  5. Right click on Xerox 6110 icon and then click "Conect"
Enjoy!
Mar 13, 2011 | Xerox Phaser 6110 Laser Printer
I have an older Phaser 6180 printer that was never used until i opened the box today. I think it was a 2007 version but never opened. I connected it to my windows 7 computer with usb and while...
You most likely need a Windows 7 printer driver.
Go to the Xerox WEB site to download the printer driver -
http://www.support.xerox.com/support/phaser-6180/downloads/enus.html
Jan 19, 2011 | Xerox Phaser 6180N Laser Printer
Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
Xerox phaser 6180n
Sounds like the memory stick is loose.
If you just received it, that machine has a one year warranty on it.
Call and Xerox will send someone out, or else they will replace it.
Your going to love that printer. WOW what print quality it has.
But your problem most likely was due to shipping and something coming lose.
Call 1-800-835-6100, follow the prompts, they will help make it right.
Jul 11, 2008 | Xerox Phaser 6180N Laser Printer
k24674
jasbo
jasbo
Marvin
Marvin
