Question about Frigidaire Refrigerators
Frigidaire Electrolux side by side fan not working
Lightning struck close to my house and took out my power the other day. I have a frigidaire electrolux side by side which I found out that the fan which is located in the freezer above the coils is not working. The coils are ok. Can I just replace the fan or do I have a bigger electrical problem? Thanks in advance for any help you can offer.
  • Frigidaire Master
  • 17,130 Answers
If teh fan had burnt out then there is every possibility that your contactor, the timer, the compressor must be checked. Replace the fan as you had confirmed and put the set on. If the compressor works and the cooling comes on fine then there is nothing to worry. But if you notice any smell or a different noise then shut off and open the back side to check from the contactor onwards to the compressor. However if the compressor works well then you are lucky . hope you get along to do this. Good day
Posted on Jul 31, 2010
Electrolux Frigidaire Model # FRT21BW8DW0 NOT WORKING, HELP!!
Hello Emily R - Do you hear anything running in the machine compartment and what type of airflow is the condenser fan providing (try removing the toe grille, located above the drain pain on the bottom right-hand side)? If you do not hear the compressor and unit is providing room temperature, it usually means the unit may have a faulty compressor or a sealed system leak. I would personally recommend contacting the manufacturer for a listing of authorized technicians who may assist you in repairing your unit and reinstalling the part that has been removed due to liability reasons.
Oct 08, 2012 | Frigidaire Gallery Series GLRT86TEW 30"...
Nothing works.
Remote receiver got fried by the voltage spike. If you have pull chain controls as well, you can remove the receiver and possibly be able to save the fan, but the capacitors, may have also been fried. If the capacitors are fried, then most likely the motor experienced some seriously high voltage too, which would mean I would replace the fan. I assume you have had the house's wiring inspected? If lightning struck the house and killed the fan, then it likely ALSO damaged other electrical components. If the lightning struck your power transformer and not your home directly, you may can get the power company to pay for this ceiling fan as the transformer is supposed to have a lightning arrester on it.
Mar 31, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
I have a 6-2003 Frigidaire side by side Model#FRS23F4CW0 Electrolux refrigerator. It gets hot in the middle of both doors the frame only. Is that normal.
Mine did the same thing and then stopped cooling within a few weeks. I opened up the lower back cover to check the coils for dust and found that the fan had stopped working. I took a box fan and blew air through the coils and it started working just fine. Now I just need to fix the fan problem and I'm back in business. Bottom line: check under the fridge to make sure the coils are able to dissipate the heat.
Mar 09, 2010 | Frigidaire FRS23F4C Side by Side...
FPE26VWCW1 Frigidaire side by side. No power to
Removed the door switch. Tested OK. Removed fan; tested OK. Put back together and it worked. However, the fan for a moment had a sound like loose bearings, so I ordered a new one.
Oct 14, 2009 | Frigidaire FRS26KF5C Side by Side...
Frigidaire clothes dryer struck by lightning
First thing you need to do is determine that it is the dryer. we had a similar problem and it turned out to be the connections in the dryer plug. you should have 2 prongs in the plug with 120volts and one hole with no voltage.
Sep 23, 2009 | GE Profile Harmony DPGT750EC Electric...
Frigidaire side-by-side stopped working
I would chech the components on the compressor. Take the cover off the compressor power terminals and inspect the relay for damage.The power outage is not a concern but the power surge could definately be the cause. hope this helps.
Jul 28, 2009 | Samsung RS2578BB Side by Side Refrigerator
Replacing frigidaire wall oven door light/fan switch
Ask the Frigidaire Agent to go talk to a technician and get the answer to your problem. Technicians are available to the Agents. 1 (800) 374-4432
May 14, 2009 | Electrolux 30" Built-In Single Electric...
Frigidaire refrigerator is warm on top of frig and freezer but fine on the bottom of both.
i suspect the fan is not working. take the back panel off inside the freezer and check that the fan is free to rotate, check for continuity thro the fan motor and check you have power to the fan
Oct 15, 2008 | Frigidaire FRS26H5AS Side by Side...
Frigidaire FRS23H5AS side by side. condensor fan runs, no voltage to compressor
i replaced the control-defrost adaptive timer pc board after lighting storm and it worked fine for ten days then i turn off may power to my house to reground the house and my frig is doing the same thing fan not running evap freezing fan not running what is going on
Apr 08, 2008 | Frigidaire FRS23H5AS Side by Side...
To me it sounds like the thremostatic controle switch has gone bad, if the fan works seperately from the system, than the switch may be bad.
Feb 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
111 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
