Question about Frigidaire FSC23F7D Side by Side Refrigerator
Evaporator coils covered in frost, and now the fan will not run. I defrosted manually and it started to work, about five minutes later the fan quit blowing. Help!!! Model number glrsf266j
  • Frigidaire Master
  • 17,130 Answers
Your fan could be faulty or the frost is building up due to failure of the auto defrost. If the fan stops working by itselt , then you must replace the fan .whereas if the fan works but stops due to frost then the speed of th fan must be checked or the auto timer must be checked for failure. You will need to trace the connections of the wores to the heaters, to the thermostat and to the timers for break bue to frost building and wearing out the wires. Get help if you are not able to do this but keep these suggestions in mind so that we concur. get estimate before you get the work done for a consenses. Hope you try this out. Good day
Posted on Jul 31, 2010
Why will my frig not do it's defrost cycle? Could it be the temp Fuse - where is it?
First off try taking a vacuum cleaner and cleaning off your coils of any dust, dirt or hair that is blocking good air flow to make sure your refrigerant is as cool as possible before it hits the compressor.
If you have frost on your evaporator coils that means the coils probably are covered in an ice layer which stops the coils from absorbing heat from your refrigerator because believe it or not, 32 F ice is not near as cold as evaporator tubes with refrigerant running thru them at about -20F or lower.
So make sure there is a nice unobstructed air flow to condensing coils and fan so the heat from refrigerator compressor can be carried away properly.
After everything is really clean, turn refrigerator completely off for the night to make sure any ice formed on the coils is melted away. Any ice on the coils will screw up the thermostats and then the refrigerator will turn on the compressor to run even when it shouldn't
So do a complete manual defrost before going back on
Nov 20, 2015 | Frost Refrigerators
Tip
Freezer not working, things to check
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator coil, warming it. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions. The condensor coil may get clogged with dirt and lint, the evaporator may get clogged with ice build up, or the fan may quit working due to bad bearings, need for lubrication, or burn out. The defrost timer has an internal motor and contacts which may quit working, some have a way to manualy turn it to switch its mode in case it quits working.
on Feb 11, 2015 | Freezers
I have a Hotpoint HSS25GFPEWW side by side.....initially the ice maker stopped crushing and dispensing ice....then the freezer started to warm. I cleaned the condenser coils and confirmed the condenser...
dead if the compressor is running and theres no cooling or frost on the evaporator you have leaked out all your freon only way to fix is call a pro about 600$ to fix
Aug 15, 2012 | Hotpoint HSS25GFP Side by Side...
The refrigerator has quit working. Lights come on and fan appears to be running. Not cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Oct 12, 2010 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool ED22PQ, 21.7 cubic feet. Freezer is not cold. Sounds like something is trying to "click on", but nothing happens.
unplug your freezer. Move the fridge 1 foot from the wall. Wait 15 minutes and plug again . if it works good , ok . if not you will need to call the technician who will check the starting relay and the compressor
Sep 12, 2009 | Whirlpool ET4WSKXS Top Freezer...
Freezer coils frost up within minutes after being turned back on
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
Aug 31, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
GE Eterna ESS25LGNA freezer side not working
How to check stuff>
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My fridge is not cooling and will get cold forming ice and later will defrost...Is this because the freon is leaking or something alse altogether?
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators ). For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
*One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
New link from Appliance Repair Aid on how the wiring circuit works for a frost free fridge, the link is here.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a SxS style refrigerator the coils will be behind a cover on the back wall.  On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. A ball of ice on the coils and the rest of the cooling coils are bare or only a few coils frosted a little and the rest are bare is an indication of a system problem. Example picture oneexample picture twoexample picture three. System problems may be a leak in the refrigeration tubing, an inefficient not 100% pumping compressor.
Feb 26, 2009 | Frigidaire Refrigerators
Refrigerator
It sounds like you found it. Change the defrost timer.
Jan 16, 2008 | Amana DLE330RAW Electric Dryer
Amana not cooling
Take the back cover off and look at the frost. If the frost is only at the bottom of the coils then you are low on R-12 or R-134 and the defrost t-stat is cutting out to quick. If the coils are well frosted then you have a bad t-stat.
Dec 09, 2007 | Refrigerators
Frigidaire FSC23F7D Side by Side Refrigerator Logo
118 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
