Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Get Fh alarm water is going in washer just fine. What are most likely causes? Model GHW9400PL0.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 31, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Ghw9400pl0 door
Your model doesn't allow for door reversal on the washer due to the electrical with the door lock, but you can the dryer there is a kit you can purchase with the dryer model number
Jan 17, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Maytag front load FH error msg
May be a water pressure sensor problem.
This tells it when the tub is full.
start with this video
https://www.youtube.com/watch?v=2pIVkAxWSXg
Nov 03, 2017 | Maytag EPIC MFW9700S Front Load Washer
Not filling
http://www.youtube.com/watch?v=_a87KTHws2M
First try turning off the machine for 30 minutes. Re-plug. If nothing happens. Disconnect from mains. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the fine filters on the machine inlet entry, they could be blocked, clean out. The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem. There is a slim tube going up from the filter area to a switch near your control board or panel; it leads to the pressure switch - it should not be blocked or leaky - ie.with holes.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on some washers.
Inlet valves can be purchased thru searching this site and fitted by you easily.
Just noted that your machine is a top load; anyways, click if helped.
Apr 24, 2013 | Hoover HTC243 Top Load Washer
Whirlpool duet flashing f and h
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the fine filters on the machine inlet entry, they could be blocked, clean out.
Inlet valves can be purchased thru the net and fitted by you easily.
Click if helped pl.
Apr 20, 2013 | Washing Machines
Fh showing on my kenmore washer
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Feb 27, 2013 | Kenmore Elite HE4 Electric Dryer
Purchased model #ghw9150pw1 used, everything seemed correct, placed clothes in washer, closed door selected and so forth. Saw small amount of water go in, then it rotated one way then the other, then it...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Sep 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do you fix a FH code ( water inlet problem) on a Kenmore Elite HE3t front load washer
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within a1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear foe several minutes then the pressure switch can be the source of the problem.
Nov 28, 2010 | Kenmore Washing Machines
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fh error on kenmore he washer. Washer stopped mid cycle and would not drain. Pulled filter in lower front and water drained but now when I try to run a cycle no water flows and I get a fh error. I changed...
The following link may give you a bit more advice on how to troubleshoot the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
The problem with this error code is the multiple things that can cause it to be generated. This can often be a bit tricky to troubleshoot. You mentioned you checked the drain pump filter. Keep in mind, if anything had been lodged in the pump impeller for any significant period of time, this could have caused irreparable damge to the pump. If the drain pump is not working, the washer will not begin a wash cycle.
I was going to recommend checking your drain hose placement for a possible siphoning situation, but you stated you had no water coming in. A siphoning situation would allow the washer to attempt to fill, but it will experience problems maintaining the proper water level.
You also mentioned you replaced the water inlet valve. Not to undermine your technical abitlities, but did you install it correctly? Verify your installation again to be sure.
Read through the link provided and look at some of the follow up comments from other users. Although, you say your flowmeter may be good, there seems to be a noted problem with them. One consumer explained to me once to make sure the flowmeter is vertical. If it is horizontal, this can also cause problems. I don't know how true that is, but its worth a try.
Another thing to consider are clogged screens in the water inlet hoses. This could be restricting your water flow. Comments from Andrewgrhogg are especially helpful on how to troubleshoot a possible water inlet valve problem.
I hope I've given you enough the go by. Let me know if you still need assistance.
Jun 24, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
118 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
