Question about Office Depot Office Equipment & Supplies
How to take apart the Ativa MD460C to clear a paper jam
FixinFax
  • 3085 Answers
SOURCE: paper is jammed in the blades of ativa mdc120b
Soak the paper jam with soapy water...seriously, it will dissolve the paper.
Posted on Sep 22, 2009
SOURCE: Clear Paper Jam error -- but there is no paper jam!
I have the same problem. Answer? PUt the piece of junk in the trash and never, never buy brother products again. I called Brother and they had a refurb for more than what it cost me originally!!!!!
Posted on Sep 09, 2008
SOURCE: phaser 860 screen says "paper jam - open front cover to clear"
I posted a problem with the phaser 860 paper jam. I found 2 broken sensor flags and am ordering the parts.
Posted on Mar 19, 2009
  • 32 Answers
SOURCE: Canon DR-3080cii paperjam
The 3 paper sensors are located along the center of the paper path. They are: Registration (lever type) on the bottom between separation & registration. Look for lever damage or torn paper. Scan Start (reflective) on the top between registration & front reading roller. Clean the sensor window with qtip & alcohol. Delivery (lever) at the eject roller. Same as reg, but harder to see due to location.The feed roller exchange kit is 6915A001. The rollers in this machine are not considered user replaceable.
Posted on Apr 07, 2009
SOURCE: I had paper jam in the Ativa Dq60M shredder but now doesn't work
it might be over heated. Just wait until it cools down and try it again
Posted on Jul 27, 2009
Ativa shredder X1800 - shredder does not respond. green light present. Reverse works fine. I killed it with too much shredded paper.
Unplug it. Lift the shredder unit off the catch-bucket. Remove any paper caught in the blades. You may need needle-nose pliers to pull jammed paper out from between the cutters.
Aug 22, 2016 | Office Depot Ativa X1800 Shredder
Runs but why doesn't paper feed into shredder?
You will probably find the intake slot is clogged.
Sep 09, 2015 | Ativa Hd1600 16-sheet Cross-cut Shredder
I placed less than 12 sheets of paper in the ativa 1250 shredder. it's reading overload. can you help?
The problem seems to be the plastic gears and/or bearing supports. Unless it is in warranty, it's going to cost you more to repair than replace, and even then Ativa's customer service is not the best and neither are their shredders: I suggest you look at http://www.complaintsboard.com/complaints/ativa-paper-shredder-c31646.html?page=2
Jun 29, 2014 | Office Depot Ativa DQ60M Shredder
Ativa MC-1010S not cutting paper all the way through Even a single sheet of paper comes out looking like a ripple-cut potato chip. Not much security there. I have used two or three lubricating...
The shredding mechanism may be jammed with debris. With power removed, access the mechanism and use suitable tools to pick out every shred of paper. I have found tweezers and a utility knife to be useful. This is a time-consuming routine, but necessary to restore proper operation.
Nov 01, 2013 | Office Depot Office Equipment & Supplies
Ativa HS1000 (Vortex) - the red light indicating that the shredder tray is full is on, however it's empty. There is clearly a piece of paper stuck in the shredder, but it's not letting me reverse...
Disconnect from the electricity. Remove the bin. Flip the shredder upside down. Brush the blades to loosen/remove any cut paper. Then using a thin plier remove any jammed pieces of paper.
Sep 05, 2011 | Office Equipment & Supplies
Paper is jammed in the blades of ativa mdc120b shredder
Sep 22, 2009 | Office Equipment & Supplies
May 03, 2009 | Office Depot Ativa DQ60M Shredder
Hp C5280 Paper Jam error - no paper + component fell apart
I am having a similar problem. An33651759-359a-4c42-a15c-e9b8d80fcfba.jpgyone know where this piece belongs? It came out when I cleared my millionth paper jam!
Sep 09, 2008 | HP Photosmart C5280 Printer
Staples SPL-1506X
Well, despite the manufacters warning label I choose to take the shredder apart and found that one of the plastic gears was broken. Hence the motor runs, but the blades do not turn. The thing I didn't understand, the there are metal gears and plasic gears...I can only imagine that the plastic gears at one point or another are going to give. I would suggest not to void the manufacters warrenty, take the shredder back, and get one that is built a little stronger. Hope that helps.
Jul 05, 2008 | Office Depot Ativa DQ60M Shredder
1,096 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Anthony Karuku
quennie732
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
