Question about Samsung Digimax S730 Digital Camera
Samsung digital s73 camera
My digital camera is blurry. like when i take pictures it comes out blurry and when i have the screen on to take the picture its blurry and i dont know why.
  • 2 more comments
  • emfield May 24, 2008
    blurry image - invarient to the distance from object. it does help to manually zoom IN. but still no longer the clear image I am used to achieving.
  • homiexnicole Jun 07, 2008
    I have the same problem, too! One day my camera was fine, then I turned it on later and everything was totally blurry. I cleaned the lense, but I used a moist cleaner and it helped a little, but it's still not clear.
  • markyboy61 Jul 21, 2008
    same problem. Working one day and the focus stops working altogether the next day
  • Anonymous Feb 04, 2009
    My sister and I have the same camera: Samsung s73: 7.2 mega pixels. After a few uses, the flash just went dead. How do we fix this?
    Novelist:
  • 150 Answers
Hi, there are many reasons why a camera may produce less then sharp pictures.
1) Dirty, oily or damaged lens: Check for dust and fingerprints.
Clean lenses with extreme caution, using dry lens paper.
Use only minimal pressure and gently wipe from the center
outwards, NEVER in circles.
If the lens is really dirty, ask a professional photo dealer to
clean it for you as a free courtesy.
2) Check to see if the auto-focus is working correctly, this could
be an electronic or mechanical problem requiring servicing.
Focus the camera on sharp image at various distances,
to see if it responds by moving the lens.
3) Can you focus the camera manually?
4) Can you focus by moving the camera back and forth
in regards to the object of interest?
5) Is the auto-focus feature somehow disabled in the menus ?
6) Are the batteries up to snuff, they may be strong enough to
turn on the camera, but too weak to move the focus motor.
7) Is the subject you are trying to focus on out of the
focus range of the lens: i.e. too close ?
8) Is the subject you are focusing on too bland, with insufficient
detail to activate and lock the auto-focus.
9) Do you have enough light for the auto-focus to operate.
10) Does the flash unit project an red pattern to help with
focusing.
11) Are you mistaking sharpness (focus) for depth of field.
In low light conditions, the lens iris opens wide, just
like your eye, to let more light in.
This results in a loss of focussed depth of field. This
means that focusing becomes much more sensitive
and critical, such that (when) the main subject is in focus,
everything behind and in front of the subject is not.
This is a theoretical limitation of all optical lenses:
The greater the focal length and the greater the aperture,
the shorter the depth of field.
This can actually be very beneficial when shooting a
portrait: Focus on the eyebrows, blur the background,
or it can be very detrimental: When trying to magnify
a butterfly on a tulip in low light conditions, getting
everything in focus is impossible.
12) Are you mistaking motion blur with lack of focus,
due to slow shutter speeds.
13) Are you shooting in very low light conditions,
causing the picture to become more noisy,
due to the way the digital camera sensor works.
14) I you come up empty on all these suggestions,
you probably have a defective camera and it is
warranty time:
a) Defective electronics
b) Defective auto-focus mechanism
c) Defective lens, loose internal elements
d) Detached sensor chip
.... etc
Try to isolate the problem. Try to manually and
automatically focus on a wide range of subjects,
at various distances, in bright daylight conditions.
If you are still unable to focus the camera,
it is probably defective and requires replacement
or servicing
BTW
Quick review of the internet, indicates that
this particular model is notorious for high battery drain
and battery connection problems. This may be the cause
of poor auto focus as indicated above.
Also this camera has insufficient internal memory, and
and an add-on memory card is required. It is possible
that without the memory card, the camera is defaulting
to a very low pixel resolution, in order to save memory
space, thus creating the appearance of poor focus.
The nominal resolution of the camera = 7.2 Mega Pixels
is respectable for such a low cost camera, but the
reliability reviews are not good.
Martin
Posted on Apr 24, 2008
My card is locked - I keep getting a message "card locked" how do I fix this?
BHG
Posted on Jul 29, 2008
I have a Digital Samsung S73 It says File Error when
Your card is becoming corrupted. Download the pics from it using a card reader if necessary...then, format the card in the camera.
Feb 21, 2010 | Samsung Digimax S73 Digital Camera
Is there a self timer on Samsung s73 camera?
Sam sung s73 camera has a seif timer. which is at the top level controls of your camera.with a clock symbol on the external button,if the button is pushed the the self timer will activate.
Feb 16, 2010 | Samsung Digimax S730 Digital Camera
Hello. My daughter has had her samsung S73 for 3
The eye flashing is normal when the flash is trying to charge up , if the batteries are healthy the camera won`t take a picture until the flash is charged fully.Try turning the flash off and see if the camera fires, get some higher rated rechargeable batteries (2000mah) or above this may resolve your problem.
Aug 02, 2009 | Samsung Digimax S730 Digital Camera
Samsung Digimax S73 - when I turn the camera on the screen is white.
hello.
you may need in this case an firmware update as a software failure.
or new lcd or defected Display IC as a hardware failure.
May 07, 2009 | Samsung Digimax S73 Digital Camera
I want to set my Samsung s73 camera back to the factory settings.
You Can Change The Size Of The Picture By Clicking The +/- Button And There You Can Select The Size Used In The Memory For The Picture But You Cannot Change The MegaPixels Used Becase MegaPixels Just Mean The Quality Of The Picture
Mar 29, 2009 | Samsung Digimax S73 Digital Camera
Fuzzy pictures
The blurry pictures are due to movement. Sometimes adjusting the flash helps.
Mar 19, 2008 | Samsung Digimax S630 Digital Camera
Samsung S73
If you don’t find a solution you may want to try fixityourself123@gmail.com. He was able to give me some great advice and he has used parts in good condition and at a good price. It worked for me.
Dec 30, 2007 | Samsung Digimax S730 Digital Camera
Samsung Digimax S730 Digital Camera Logo
544 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
