Question about LG Washing Machines
Lg intellowasher wd-8050 fh, lights come on but no functions will work
SOURCE: LG WD 8050 intellowasher Front loader
My machine is spinning OK, but it has a terrible smell of rubber? oil? burning?
Last month I rang LG who said I should have been using Scalex (first I heard) to descale the build up, and they sent me a sample.
Well, it helped for a couple of washes, and I bought some more and used it at least 10 times now, but the smell is worse than ever - can't even wear the clothes. So it is time to ring them again.
Posted on Nov 07, 2007
SOURCE: my lg intellowasher 7kg WD-1059 FB will not pump
Pump motor is probally shot, Mine is 4 years old I'm replacing mine again. Yes I've replaced it twice
Posted on Feb 23, 2009
  • 44 Answers
SOURCE: i need a manual for an LG washing machine model
You can download the 20 page User Manual here: http://diplofix.com/foro-LG/WD-1050FH
You have to enter the code that appears when asked.
The Exploded Parts View is here: http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/LG/LG%20Washing%20Machine/WD-1050FH%20Ex%20View.pdf
The Parts List is here: http://74.125.95.132/search?q=cache:rXGnH0DUc2AJ:www.stokes-aus.com.au/StokesAP/Manufacturer_Info/LG/LG%2520Washing%2520Machine/WD-1050FH%2520Parts%2520List.xls+WD+1050FH+manual+LG&cd=5&hl=en&ct=clnk&gl=ca
I have copies of all of these if it needs to be posted elsewhere.
Posted on Aug 05, 2009
SOURCE: cant open door
Dear all, I have a problem with washing machine model wd-8013c, then you wash white laundry receives water and immediately released, and it does not happen with colorful Vesa. Best regards.
Posted on Jun 30, 2010
jumptrout51
  • 3361 Answers
SOURCE: Manual for LG Intellowasher 7kg
While not exact to your model,this manual may answer your questions.
http://136.166.4.200/contents/Laundry/WD-1070FH/WD-1070FD_Service_Manual.pdf
Posted on Sep 08, 2010
Temp lights flashing LG intellowasher WD 80100tp
it appears the diagnostic computer has found a problem with the water inlet servos and may need replacing contact LG for replacement parts
Jul 29, 2016 | LG Washing Machines
How do I clear the CL code on the display of the washing machine lg intellowasher 7kg WD-12235FB
The Child Lock function on your washer has been enabled. Press the options buttons simultaneously for 3 seconds to reset.
May 11, 2015 | LG Washing Machines
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
Lg intellowasher wd 10160f
Check the Lid Switch Assembly with an Ohm meter for continuity, these switches are a common problem. Replace the switch assembly if faulty.
Mar 18, 2014 | LG Washing Machines
Need the operating manual for a lg intellowasher 7.5 wd-1018c
go to www.lg.com/au then click on product support left hand side of screen then type in wd-1018c in search box under box high lighted in red wd-1018c washing machine comes up. click on it. half way down page down load pdf for manual
Oct 10, 2010 | Washing Machines
Lg intellowasher wd-8013f is very noisy
You suspect right.
It is a complete strip down job. I have just finished mine.
taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers.
Download the manual from LG.
Good Luck
Mar 17, 2010 | Washing Machines
Lg washing machine error message
Possible that water solenoid valve died. Unplug the unit to clear error code, and try to fill using only hot water. Try the same procesude using only cold water.
May 02, 2009 | LG Washing Machines
Washing Machines Logo
78 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
