Question about Matrix Okidata Microline 320 Printer
THE 320 OKIDATA TURBO IS NOT LINING UP ON MY PAPER. IT'S TAKING TO 2 SHEETS OF PAPER TO PRINT ONE INVOICE
  • 65 Answers
Give this a try.
let me know if this helps.
Joe
Posted on Mar 26, 2009
We had a computer crash that required replacing the computer we had with one running Windows XP w/SerPk 3. We are still using the okidata microline 320 turbo that we used with the old computer. We are a...
The most current driver for this product is already included in the Windows XP Operating System. Currently there are no updated drivers available.
If the driver did not work, try to use the IBM Proprinter or Epson LQ driver.
Mar 16, 2011 | Matrix Okidata Microline 320 Printer
We print a 3 part Invoice and the print on page 2 & 3 are so light you can hardly read them.
On the left side of the ribbon holder is a blue lever. move this towards the paper (rear of the printer) until you get clear prints
Dec 13, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Installed a new okidata microline 320 turbo dot matrix printer and now the tear/set button does not set the paper where i need it to as my old printer did. How can i change the tear line setting?
Make sur that the paper length is correct in the settings. With paper in the printer hold down the "SHIFT" button then press the "SEL/MENU" button. The "SEL" indicatr will light up. Now press the "PARK" button, a settings page will print. Select your paper length you require by going through the settings, if you press the "LF" button it wil take you through the different groups of settings, the "FF/LOAD" button wil take you through the different items in the groups and the "TEAR" button will change the settings on the different items. To save the new settings hold down the "SHIFT" button and press the "SEL/MENU" button.
Aug 20, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Problem with new installed printhead
If I remember the 320, there is a head-gap adjustment that is normally moved for replacement of the head and must be reset again. Check your manual for that term; 'Head gap adjustment'
Aug 18, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata Microline 320 turbo problem
Solved this problem by going into the bios and changing the port from ECP to EPP, and then uninstalling the ECP port in device manager and replacing it with a standard parallel port configuration, no problems since doing that.
May 12, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata ML320 feeding blank sheets
Which IBM driver are you using ? try using a IBM proprinter driver.
Hope this helps.
Dezzi
Mar 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printing jibberish
Hello babytenbucks,
I can help you setup your Okidata 320 printer.
Connect the printer to the printer port coming off the motherboard. Usually it's colored pink. Also known as LPT1.
If your operating system is Win XP do this. Open Control panel, open Printer & Faxes. Click File, Add new printer.
Uncheck, automatically detect & install my plug & play printer.
Click Next. Allow it to use LPT1. Click next.
There are two windows here. On the left is Manufacture on the right is Printers. Scroll through Manufacture till you find
Okidata. Under Printer, scroll down till you see Okidata ML 320 Turbo/D (IBM), click next. You can give it a new name or leave it as is. Make the 320 the default printer. You can let it print a test page. Either way re-start the system. Try another test page.
Click the link below for a .pdf file which is the manual for your
Okidata 320 Turbo.
http://www.precision.com/manuals/Okidata_ML320_321_Manual.pdf
If you do not have Adobe's pdf reader download it from the next link.
http://adobe-reader.download-express.org/now/
babytenbucks, if your still have any trouble please just post back & we'll get it solved.
Good day!
& please vote...
Feb 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata microline 320 turbo 9 pin printer
What driver are you using, you should try the IBM Proprinter Driver.Hope this helps.
Dezzi
Feb 11, 2008 | OKI MICROLINE 320 Matrix Printer
350 people viewed this question
Top Matrix Office Equipment & Supplies Experts
Dimitar Todorov
ray gallant
Electro Med Services...
Are you a Matrix Office Equipment and Supply Expert? Answer questions, earn points and help others
