Question about Honeywell Heating & Cooling
Hi, I'm fitting a replacement Honeywell Motorised Valve in my hot water system. I've got a spot of bother with the wiring. The one I'm fitting is a V4043H-1056 and had 5 wires but the faulty one that is on there is a V4034-1106 which has 6 wires coming out of it - all the same colours but with an extra white wire. Have I got the wrong valve or can I ignore the white wire? The fitting instructions for the value show an 'S'-Plan which does not have the white wire and a 'C'-Plan with the white wire. I'm confused as to why my motor does not have the white wire when the instructions suggest that it should be possible to fit 'C'-Plan with the white wire. All suggestions welcomed. Thanks, Doug
We are selling a full case of 35 Aux. switch assembly for V4034 on ebay 10-31-08
if you or anyone is interested
Posted on Oct 31, 2008
How do I fix central heating
The first thing you need to substantiate is the fact that there is enough water in the system. It will be a closed loop system requiring approximately 10 psi/ floor. (Only a rule of thumb). Usually when one protion of the system works and the other does not, it is an issue of water quantity available to circulate through the combination of loops. If you have to add water, you will probably have to purge air from the highest points in the system. Even if there is an "Airtrol" fitted in the bottom of the expansion tank, bleeding the high points will eliminate air quicker.
The hot water portion of the loop should only be going through a heat exchanger that transfers the loop temp to the domestic water circuit and the three way valve is probably a 'mixing valve' utilized to maintain a certain loop temperature on the primary loop.
Dec 01, 2014 | Honeywell Heating & Cooling
I had a Honeywell F4- 0019 motorised two port valve on my central heating that has failed. I have replaced it with a Honeywell valve from Thompsons Plumbase, but on fitting noticed the new valve has six...
I'm doing a lot of guessing here for lack of information. You have a residential boiler and hydronic heating system that is zoned around your home and each zone has an independent thermostat?
Again, I need to guess. The old valve was spring return with yellow, blue and red wires? If all is true so far, then I think you had a single end switch with one COMMON - one NORMALLY OPEN and one NORMALLY CLOSED contact. 6 wires would make up 2 end switches. Brown is a normal color for one lead of an end switch. If this is all true, your new switches are probably NORMALLY OPEN and you only need 1. If this did not help you, give me a better description of old and new and I will get this correctly answered for you.
Apr 01, 2011 | Honeywell Heating & Cooling
I think my motorised valve is not working. I replaced the thermostat, have it down to 55 and there is still 70 plus temps in heat. system is 3 zones. i bought the replacement honeywell unit today. the...
I am having a similar problem mine will not shut down but what I understand from the service man is the valve should work on Automatic... manual is for a defective valve and you can force heat through by setting it on manual...
Jan 18, 2011 | Honeywell Heating & Cooling
My Honeywell ST 6400C won't heat the hot water the light comes on but pump doesn't run or boiler fire. But does work on C/Heating.I can get hot water only by running the C/H and manually opening the hot...
it sounds like the motor in the motorised valve is not working on some models you can just change the head /motor , check cylinderstat (hot water stat) is working
Dec 14, 2010 | Honeywell Heating & Cooling
Solid fuel stove linked to oilsystem with two zone
Put a temperature operated control (aquastat) on the piping of the wood stove so that if it is on, it will interupt the circuit wired to the oil burner at the X&X terminals of the boiler control.As the wood stove cools off, it will close the connection allowing the oil system to fire.
Mar 04, 2010 | Honeywell Electronic Programmable...
My Honeywell 3 port valve in my CH/hot water systemis not working
Hi two things that go wrong inside the valve gets clogged up and blocks up in side, the valve in side and get worn sorry 3 things the motor on the top burns out , if you remove the top cover you will see a small motor with 2 orange wires on it you can remove the motor with 1 screw and see if its turning
Feb 08, 2010 | Honeywell Electronic Programmable...
Ariston Microgenus 27 boiler - leaking motorised valve
The leak is coming from a seal around the pin that the motor acts upon, the seal does not come as a replaceable part on its own, so the whole flow group as it is called will need to be replaced, approximate price 170 to 200 pounds inc vat, makers part no 998613. plus 2 or 3 hours labour of a corgi registered engineer. If your boiler is more than 6 years old and you have not had to replace the fan or other parts yet, then think about getting a new high efficiency boiler, it could be a better long term solution.
Feb 15, 2009 | Combi Centre DX - Mango
How to wire in a honeywell 9400c timer clock 4 ch
One of these wires is contains permanent live, neutral and earth. The other wil be heating on and hot water on, the earth on this wire will probably not be used.
you will have to trace the wiring back or test it!! Be carefull!!
Dec 11, 2008 | Heating & Cooling
My boiler keeps firing up even when the Honey well programmer is in the off position. The programmer is about 7 years old.Do I need a new one, a new battery for it or is it to do with the boiler (oil)...
I had the same problem. I traced it to the micro switch in the water/central heating motorised valve having shorted out.
I replaced the (Honeywell) motorised valve and it is now only running when it should.
May 01, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
267 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
