Question about Honeywell Heating & Cooling
I have a honeywell R8182H J aqua primary control On my heating boiler system. there is 3 adjusting knobs on it. what should they be set at?
2 Suggested Answers
22yooper
  • 828 Answers
SOURCE: My central heating system comprises
You could possibly have an ignition problem. The controller will go into a lock-out condition if flame is not established. Turning the temperature control down and then back up may be serving to reset the control system so it tries again.
Posted on May 22, 2008
SOURCE: Burnham ledv boiler, honeywell primary
I'm sorry to hear! On mine, another model of Burnham , there's a grey box (approx 4" high by 5" wide) on the front of the boiler. This cover slides off and the control settings are underneath. My manual says low limit must be 20 degrees below high limit else they will lock out each other. I find this to be the case when a maintenance man's "tuned" the settings. My manual also says to set the differential knob to 25 degrees. There are some manuals on the burnham.com site along with their phone number.
Posted on Jan 15, 2009
IVE GOT A HONEYWELL T87A 3 WIRE THERMOSTAT MOUNTED ON THE WALL AND WHEN I WANT TO TURN ON MY HOT WATER BOILER I HAVE TO LOWER THE T-STAT SETTING INSTEAD OF INCREASING IT TO GET THE HEATING SYSTEM TO TURN...
I would switch to a two wire heating only stat It sounds to me like they have the boiler wired into cooling side. Do you also have to set switch on your t-stat to cooling or leave it on heating. Just curious. I would still go with two wire stat. Thanks.
Nov 11, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
I have installed honeywell aquastat relay per instruction manual on my dunkirk xeb-4 lp boiler furance with honeywwell ignition unit s8610u but it wont ever start the exhaust fan checked everything several...
If aquastat wirings are ok, and control module had been set up properly, the the furnace should start.
Check if bypassing the control the furnace starts, if it starts then check aquastat wirings.
If it depends on the furnace, check the valve, the safety sensor and the ignitor.
Here is the guide to set up the Aquastat control:
Guide to Setting & Wiring Heating System Boiler Aquastat Controls
Sep 13, 2008 | Honeywell Heating & Cooling
My Baxi Solo 3 PF60 Boiler was serviced 2 weeks ago be a Corgi registerd agent. The Boiler had worked very well in fact and up until last Sunday morning when the boiler failed to come on. On inspection,...
It could be something as simple as an improperly placed thermostatic sensing bulb. Those controls are pretty tough. Look for obstructions that would cause air restrictions and overheating. You've done all you can do then. Call the tech back back and get him to check or replace the aqua-stat.If it turns out to be ok them your limit may be weak and in need of replacement.
Oct 27, 2010 | Kitchen Ranges
How do I wire a Honeywell R8182H and a R845A controls to a R7184A
use the h an the 845 1 zone to the h an 1 zone to the 845
Dec 17, 2009 | Heating & Cooling
Temperature fluctuates
Actually that thermostat is adjustable for only +/- 1 degree. I would make sure it is located close to a radiator/register, whichever you have, to help close that 8 degree variance. The thing about hot water heat is that even when the boiler shuts down those radiators are still putting off heat, so the temp can still shoot up a few more degrees after the stat has been satisfied. Is the boiler shutting down when the stat hits 71* ? If not then the stat may be bad. Honeywell carries a 5 year replacement warranty on that stat. I use the Honeywell Focus stats in almost all my installations. They are a very dependable thermostat. Feel free to ask anything else that will help solve your problem...Rob
Dec 16, 2009 | Honeywell Focus 6300B 5-2 Days...
I have just had a new boiler fitted and wanted to run the thermostat (honeywell cm921) on auto, the electrician set the timer to come on at 1 & off at 2 disabled at 3 & 4 and on again at 5 and off...
Complicated because I need more info....but in General a Boiler should not be on a Programmable Thermostat as it takes too long to heat etc...do you have Radiators in your house???Or ductwork for heat???It will make a difference...if you put the boiler on a program it may come on anyway as some boilers maintain there own internal temperature regardless of the thermostat.....if you want to run it on a program adjust the temperatures so there is only about a 2 degree swing....70...down to 68....back to 70.....etc...there should also be a switch in the thermostat to set for Boiler...or Electric heat...make sure that switch is on...otherwise its difficult to give you a more conclusive answer
Nov 11, 2009 | Honeywell Programmable Thermostat Heater
Need to wire a honeywell RTH7400D thermostat to 3 wire hot water
Just mark the old wires on the old thermnostat...R , W etc...and put them on the same terminals on the new 1.....also there should be some adjustment ire : switch on the back or under the cover to adjust for Hot water heating or electric heat...either is the setting you should have it on....also you shouldn't setback the thermostat at night or when away very much....2 degrees is fine , as the boiler will run along time to raise the temperature in the morning and may not get there by the set time
Oct 18, 2009 | Honeywell Electronic Programmable...
Boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Oct 05, 2009 | Honeywell Programmable Thermostat Heater
Chronotherm Three thermostat vs Buderus Logamatic Computer.
The outdoor thermostat senses the the temp of the outside air, and adjust the boiler water temp according to what it knows is best. The reason that the boiler is running longer is the old boiler used to be constantly sending 180ish degree water to the baseboard, now that water may only be 140ish degrees. The idea behind this is to reduce off cycle heat loss, as the greater the temp difference between the air temp and water temp, the quicker you loss heat. The theory in boiler run time is this, the less times it starts and stops, and the long run times will give you the best efficiency. Hope this answers you questions.
Sep 28, 2009 | Honeywell Power Humidifier: Furnace...
Burnham ledv boiler, honeywell primary control will lockout after 1 or 2 cycles. reset, get the same results. works fine during the summer
Nov 11, 2008 | Heating & Cooling
Heating & Cooling Logo
207 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
