Question about Linksys WRT400N Router
I reset router....am having problems connecting to internet. I can connect as long as I have the ethernet cable connecting from the computer to the router. When I take out cable from computer, connection is lost. Help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 196 Answers
You need the Ethernet Cable in your Router to be able to connect to the Internet.That is the only way your going to be able to have Internet.It will not work without the Ethernet cable.
Posted on Jul 31, 2010
  • 1 more comment
  • Jlgray1204 Sep 28, 2010
    @1trinity I can't believe you would state that the only way to get internet from a wireless router is to keep it wired. Ridiculous!
    Answer: go into the router setup (192.168.1.1) or (192.168.0.1) and under basic setup, change the ip address of the router to 192.168.2.1. Click save at the bottom.
    It will say something like, settings were changed successfully, reset ip renew ip adress.
    DO NOT CLICK OK TO CLOSE. Unplug the router, wait 5 secs and plug it back in. Wait for the prompt and you should be able to unplug the Ethernet.
    I know this post is 2 months old but i couldn't leave the Readers with this nonsense as a final answer to the question.
  • letterfro793 Sep 28, 2010
    Thank you jlgray1204 You are the best!
  • jacqueline sanders Sep 30, 2010
    You need the ethernet cable in the router to have internet unless you have wireless USB adaptors
No internet or lan lights on? Tried reset, hard reset. All other lights, power, wireless, router are on and green. No lights on internet and lan connection. I have tried another wireless router and have no...
The LAN lights will only turn on once you have an Ethernet cable connected to it and the other end of the cable is connected to a working computer.
If you already have a computer connected to the Ethernet port of the router via an Ethernet cable and the lights are still off. Check if the computer you have connected recognizes a network via LAN.
If the lights on the router are still off and the computer doesn't recognize a network then that means that the port for the ethernet of your Router is bad and sadly there's no way of getting that fixed but to have the router replaced.
Otherwise if the lights are off and the computer recognizes the Network and lets you connect to the internet or other computers on the same network then its just the LED of the LAN light that's broken and I think you can live with that.
Hope this helps!
Jul 18, 2011 | Buffalo Technology AirStation Nfiniti...
I have been using this router for a few years now and have not had any problems until now. i contacted optimum online and and they were able to get me on line by over riding the router; however, when i...
Hi, below are the steps we need to follow:
Step 1: Unplug the end of the Ethernet cable from the back of your computer and connect it to the Internet or WAN port of the router. This will now connect the modem and the router.
Step 2: Take a different Ethernet cable and plug it into the Ethernet or LAN port of the router and connect the other end to the computer. The connection sequence now would be modem > router > computer.
Checking the LEDs
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected is lit.
Configuring a Linksys Router for Cable Internet Connection
At the back panel of the router, there is a reset button, reset it for 30 seconds and we can proceed to the next step.
Step 1: Access the router's web-based setup page. Open internet browser like internet explorer. On the address bar type 192.168.1.1 and press enter. That will be prompted us for username and password. By default, leave the username blank and password is admin(lower case).
Step 2: On the Setup tab, click the MAC Address Clone sub-tab.
Step 3: Select Enabled, then click Clone My PC's MAC.
Step 4: Click Save Settings.
Step 6: Check the Internet IP Address under the Router sub-tab that's on the upper right hand corner under status. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet.
Dec 22, 2010 | Linksys Wireless-G WRT54G Router
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
Please clarify what you mean by ''Connect with an ethernet cable''
Ethernet cable means CAT5 or UTP for others or LAN cable. The connection should be LAN port of your computer to LAN1 of your router.
And you can connect also the internet cable usually ethernet cable from your internet provider directly to (ethernet cable)WAN port of your router to get signal from your internet provider.
Also if you get this message, this could also means you still don't set up or configure the router's settings to communicate when your LAN and router. They must see each other to access the router's utility webpage.
Regards
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
Ethernet speed changes from normal to zero
If you have high speed internet go to your ISP webpage and do a speed test. If You are paying for say like 10 MEGS and are only pulling 1.2 Megs. It probably is your modem. Your speed will slow down to approx 7.5 behind a router. Also Your ethernet cable might need replacing. might also might try resetting your router. disconnect all power even the cable comming in and reset everything. Hope that helps.
May 24, 2009 | Apple eMac G4 Desktop
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
Issue with router and ethernet cables
I imagine you reset/unplugged all of your routers, switches, and computers, starting with your modem, then router, and then each system?
There is a setup disk that need to be used to program your router with the ISP settings, passwords, and protocols for port forwarding, etc. I imagine you tried that.
Did you try all of your cables to make sure they weren't defective?
If you tried these,and the problem persists, the issue is a defective router. By default, the unit should transmit a wireless signal, and be ready to act as a routing switch for your other systems.
Mar 26, 2009 | NetGear WGR614 Wireless Router
Linksys Wireless-G 2.4Ghz Broadband Router Problem
You have to check if your computer can connect to the modem with an Ethernet cable. This will tell you if the ethernet port on the modem is working. if that does not work call your cable provider.
Next thing after you get the instructions above done.
Press the reset button on the back of the router> press it in for 30 seconds then let go and pull out the power. Connect the router up the way it should be before you reset by the way. check if you have internet if you do not follow hte directions at teh link below.
CABLE SETUP
If you need more info just message me
Aug 29, 2008 | Linksys Wireless-G Broadband Router
Ethernet vs. usb
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Feb 09, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Linksys WRT400N Router Logo
196 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
