Question about Kenmore Dishwashers
We have Kenmore that is 7 years old. It is one of these models : 665.11072912; 665.11072913; 665.11072914: 665.11072922; 665.11072929. The dishwasher is making a very very loud sound, taking very long to run and is not cleaing dishes. Water is coming out and draining. Water is very hot. Could the filter be blocked and if so how do we access it to take a look and clean it out Candace
bigg t
  • 640 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Posted on Feb 24, 2008
dutchman05
  • 487 Answers
SOURCE: Kenmore dishwasher series #168790 not cleaing dishes
Hiya,
Please clean filter in the bottom of the machine.
Even can clean out the pump. than start a wash empty and as soon as it has filled up put 3 cups of vinegar in the machine. Let it run on hot.
this should fix the problem
Also please take out the arms and make sure all the holes are not obstructed.
This is a simple way of cleaning but effective
Posted on Apr 26, 2008
SOURCE: kenmore elite dishwasher making loud buzzing sound when washing
I had the same problem with by Kemore Ultrawash after two years. The motor bearing went bad because the seal went out and dish water got to the bearing. If you are handy, this motor comes out after taking the dishwasher out. I was surprised how easily the motor came apart from the dishwasher, a good design. The motor has three screws that holds it together, I took them out and took the motor apart.
I took the old beaing off the shaft with a grinder, careful not to groove the motor shaft. I did, but just put some high temp silicone caulk in the groove before I put the new bearing on the shaft. I bought a new bearing on the internet, it is a 22mm x 8mm x 7mm. I bought one that went in a small engine, a quality one. I placed it on the shaft, put the motor back together and put the dishwasher back together. It has run quiet and great for many weeks now. I expect the dishwasher may last many years now, because the bearing I took out was a cheap aftermarket one, and the new one is vastly superior in quality.
Good luck and fire away with any questions. I love this dishwasher and am glad I could fix it for 19$ and some of my time.
Posted on Nov 08, 2008
  • 9 Answers
SOURCE: Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Posted on Jan 02, 2009
reg501
  • 413 Answers
SOURCE: I have a kenmore 665 dishwasher where the spary arms do not spin.
  • First, check water level. Start machine, wait until the machine begins main wash. Open the door, the water level should be just below the heater element. If too low replace inlet valve.
  • If you can't hear the wash motor running or is just humming, the motor may be bad.
  • To check if the food chopper is blocked or broken;
  1. Remove lower spray arm by holding the arm and rotating the spray arm retainer.
  2. In the back of the tub, unclip or remove the screw from the upper spray arm supply tube.
  3. Rotate the lower spray arm support to the right while disconnecting the supply tube from it.
  4. Remove the four torx screws from the sump cover, remove assembly.
  5. There may be a primary filter in the left side of the sump, if so, remove the torx screw and the filter.
  6. On the right side there is the chopper assembly cover. Remove the torx screw and cover to expose the chopper.
Hope everything goes well for you,
Regards
Richard
Posted on Feb 03, 2009
Can you tell me what year and capacity/cu. ft this dryer is? Kenmore mod. 110.74642400 s/n 1505525.
Looks to me like a 7 cu ft model whirlpool type dryer with filter in the top (very dependable for over 50 years) this one is around 10 years old and is one of the best out there.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 23, 2012 | Dryers
Kenmore front loading washer drum is loose and makes loud noise when spinning?
sounds like support springs for the drum have become detached or broken. Do not use, suggest new machine as old ones not worth the investment.
Oct 01, 2012 | Kenmore Washing Machines
10 year old kenmore model 110 gas dryer drum turns but will not dry clothes
I have a Kenmore Model 110.74612200 it came with the house and needs another service call-not heating- how old is this model? Wondering if it might be time to buy a new one. Dryer has seen a lot of use in the past 5 years from a household of six.
Feb 21, 2010 | Kenmore 63942 Dryer
I am trying to find the model of my Kenmore Dryer... Its an old HE3 going on 7 years old.
Hi, The model number is always located on the inside of the door jamb for Kenmore's. If for some reason it's not there you can remove the panel under the door, Normally 3 screws along the bottom lip. Behind this panel there should be a tech sheet. The model number should be on the tech sheet. If you have any additional questions please feel free to comment. Mike
Dec 10, 2009 | Kenmore Dryers
No heat in any selection Kenmore Model 110.60612990
remove the back panel and check the heater box fuse and the heating element-mike
Jul 24, 2009 | Kenmore 64902 Electric Dryer
Kenmore Gas Dryer is 7 years old. It will heat up
Replace the gas valve coils. Common problem after 3-4 years.
Jul 05, 2009 | Kenmore Dryers
Clock
What country are you in. This model does not show up in Kenmore USA
Perhaps you gave me the serial number by mistake, rather than the model number?
Dec 21, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore built in dishwasher is leaking out the front
change the door gasket. also check to see if the wall hasn't "sprung out" of position this will always cause leaks if the side walls aren't supported.
Feb 02, 2008 | Dishwashers
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
