SOURCE: remote codes for Emerson Symphonic tv?
I have a symphonic tv and a emerson universal remote cannot find code anywhere for this tv???? anyone know what to do cheap tv
SOURCE: need remote code for emerson LC195emx LCD TV
hi! i have here a couple of codes for your emerson tv. you could try them 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037 hope it would work! goodluck!
SOURCE: I have an Emerson HD digital TV model LC195EMX,
The indication of the standby light shows that the sub power circuit is functioning alright. Now on depressing the switch on power if there is no reaction then the main processor is getting an errror message for no switching. If you are getting any click and shut off then there is a power short/ fault in the HT circuit which requires further probe. You can check the main fuses and for dry soldering joints/ loose connectors in the main PCB, if all this is fine, I suggest you get help but ask your technician to give you an insight if the fault is in the control, main power (SMPS) or the HT. I hope this adivce helps. Good day.
SOURCE: What is the digital remote
Ok, what kind of universal remote do you have?? With this model there are several that work. Emerson has a lot of codes so you need to go through them and see what works well with you.
Sorry for the long list but there are always more than one that works. Some Universal remotes also let you use more features with some codes so you may want to try a few and see what works well with you
Emerson 3 digit remote codes:004 009 014 023 024 025 026 027 030 032 033 034 035 036 037 038 039 040 041 042 043 045 046 049 053 116 135 147 177 179
Emerson 4 digitl remote codes:0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250
Please let me know if you need help of what kind of remote you are using and I can try to narrow it down.
Thanks again
