Amana Heavy Duty, Model: LW8303W2, MFG NO: PLW8303W2. Intermittent problem of not draining and not spinning. When this happens, it advances and starts the next procedure on the dial. Usually use the "Normal" cycle so it advances to the "permanent press" cycle. Sometimes ending the second cycle with the tub full of water.
4 Suggested Answers
SOURCE: Amana Heavy Duty Extra Large
my heavy duty 7 speed motor cut off because of over heating and the belt was changed can you suggest a suitable model of fan belt for it. ?
Posted on Aug 20, 2008
SOURCE: AMANA HEAVY DUTY WASHER
my amana ,soon i turn on always start to leak no much.?
Posted on Jan 27, 2009
SOURCE: what size is an Amana
I had the very same question, so I can buy a replacement that is just as big. Not finding the answer online, but only your question, I measured mine and calculated the volume at about 2.5 cubic feet. I am surprised it seems so small, because it is labeled as an extra large capacity. Of course, it is now about 15 years old, so maybe the new ones are mega washers or something. I wonder if I will get that much time out of a new one.
Posted on Feb 08, 2011
Amana heavy duty super capacity dryer heating element location
get the Model # and then go to Repairclinic. com
Jun 28, 2013 | Washing Machines
Producing debris when in spin cycle
2.13.1 Scrud
If fabric softener is used regularly it will eventually cause a build up within the outer bowl. This can
result in black flakes present in the wash load that can stain garments. To remove scrud follow the
procedure below.
Step1: Add a full cup of a good quality dishwashing powder such as Active or a similar product
into the machine.
Step 2: Set the machine to a Heavy Duty cycle, select a Hot Wash temperature, High Water level
and allow the machine to agitate for 10 minutes.
Step 3: Leaving the lid closed, turn the machine off and allow to soak overnight.
Step 4: The following day, turn the machine on and advance to the spin cycle to drain the water
from the machine. After the water has drained, turn the machine off then back on again, and select
a Heavy Duty cycle, Hot wash, High Water level, and allow the machine to complete a full cycle to
ensure that all of the loose scrud and residual detergent has been flushed away.
Note: If there is an extremely heavy build up the bowl will have to be removed for pressure washing
Dec 15, 2012 | Fisher and Paykel GWL11 Top Load Washer
I have a frigidaire 9 cylce-heavy duty-2speed ,model fws445rfs0. It fills with water, drains water but won't spin on the spin cycles. I was trying to remove the middle spinner piece inside to see if...
for schematic try:http://www.partselect.com/ModelFrames.aspx?ModelID=1004870&ModelNum=FWS445RFS0&mfgModelNum=&ManufactureID=4&Selected=ZH8J52ZV&Position=4&mfg=Frigidaire&Type=&Mark=4
Feb 02, 2012 | Frigidaire Washing Machines
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Amana Heavy Duty Extra Large CapacityTop Loading Washer 2 speed - 10 cycle Mod. LW8413W2 Mfg. No. PLW8413W2A S/N R-9504056772 Occasionaly,At the end of a wash cycle it will continue on to the next...
Jul 07, 2008 | Washing Machines
Washing Machines Logo
197 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
