If u took the bed off to change the fuel pump make sure u hook the ground back up to the frame the ground should be on the driver side behind the tank,u need to change the fuel pump relay when u change a fuel pump because it could be bad to cause the first pump to quit working. not the right amount of volts or to much volts,the relay is under the hood in the fuse box,
Try looking for the "inertia fuel shutoff" reset button located on passenger side under the carpeting....
