Question about Makita & 1/2 Inch Drill
How to change drill chuck for makita hp 2040 - Makita & 1/2 Inch Drill
    Problem Solver:
  • 5 Answers
If its a reversible drill there will be a screw in the bottom of the chuck, open the jaws as far as they will go and you should see a screw head, it is a left hand thread so put the drill in low speed selector this will stop chuck turning as easily, then turn screw clockwise as your looking at the chuck, when its out put an allen key in and tighten up the chuck hit with hammer now in a anti clockwise direction it should unscrew. repeat in the reverse procedure to fit new chuck....
Posted on Jul 31, 2010
Changing the chuck of a 6408 makita electric drill
Open the chuck and remove the screw inside the chuck (if fitted) the screw is left hand thread, fit the short end of the largest hex key that will fit into the chuck and tighten the chuck, put the drill into low gear and turn the clutch to the drill position, support the drill on a bench and strike the long end of the hex key with a firm blow (right hand thread) it may be neccessary to strike it more than once
Jan 30, 2013 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita HP 1640 hammer drill chuck loosens grip on drill while drilling
Sounds like the chuck is worn, happens frequently when used often. Here's the link to Makita, their contact info should get you some answers as to what part number is needed as well as the closest location to you for service if required. Hope this helps.
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=316372
Jan 14, 2011 | Makita HP1640 58Inch Hammer Drill
I have a 12v makita drill and cannot remove the chuck i have removed the screw inside the chuck. lease help
The chucks on most drills are left hand thread. To be sure which way to turn the chuck check the screw the chuck will turn in the opposite direction.
Mar 29, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
The chuck need change on drill modle hp 1621
you can either go to the tip section or try going to my profile under my user name and there are detailed instructions on how to remove the chuck.
Jan 17, 2010 | Makita Drills
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
Oct 05, 2009 | Makita Drills
Change the chuck on a makita DA39DA coredlesss right angle drill
look inside the chuck for a screw. it will be a left handed screw.once you get the screw out put the chuck in a vice . you will need to squeeze it very tight. then put the drill in reverse and pull the trigger.if i wont come off you will need to hit the chuck with a hammer while you are holding the trigger.
Aug 20, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
May 04, 2009 | Makita Drills
Makita 6405 3/8
according to my breakdown its a drill. do you checked if there is a screw inside the chuck. if there is one remove it by turning clockwise.open the chuck fully & insert allen key 5/16 or 3/8 short side to the chuck.tighten the chuck & wak the allen key with a hammer counter clockwise. do it again if required.putting back together the other way.
Jun 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Chuck change
After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
May 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita & 1/2 Inch Drill  Logo
607 people viewed this question
Top Makita Drills Experts
John Trevino
epangan29
Mike
Are you a Makita Drill Expert? Answer questions, earn points and help others
