Question about Bosch Washing Machines
Bosch maxx classic have cleaned filter front bottom corner, machine seems to be leaving lint on clothes and dull spots on new business shirts
How to clean the rubber around the door of front loader gets black dirt
Posted on Feb 12, 2011
How do I find clean the filter of our bosch maxx classic 900 rpn front loader? I can't even find the filter.
Filter is located bottom left of machine it has a small black hose tucked inside ,you would remove the Plug on the end of the hose and drain any excess water into a container then unscrew the filter anticlockwise to remove the filter any object within will now bw apparent... Good luck.
Feb 16, 2015 | Bosch Washing Machines
How do I find clean the filter of our bosch maxx classic 900 rpn front loader? I cant even find the filter.
You don't. Washing machines don't have a handy accessible filter...
Check the owner's manual that came with the machine.
I have a Maxx Classic WAE20261AU/01 front loader. The machine won't start because the door won't lock. The door has been playing up a bit for about 2 months, but now it won't lock at all. It is...
Sorry. It seems that I have fixed it by using your solutions!
I drained it and cleaned the filter thing down in the bottom right hand corner, put it back to gather and then it turned on again!
Interestingly I found a bobby pin down there!
Thanks for your assistance John_Cross!!
Jun 21, 2011 | Bosch Washing Machines
Cannot get out and clean the washing machine lint filter. We can open the service flap and unscrew the pump cover, but the lint filter does not come out. Our washing machine ia a MAXX Classic. Thank...
Manual is here...
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=rhdu2Hjcdcso0pdmdb---hNm&UMOBID=rhdu2Jhcdcso0pdmdb---hNm
Go to page 26 for instructions.
Mar 20, 2011 | Bosch Nexxt 700 Series WFMC6401UC Front...
How to clean lint filter of Bosch Maxx Classic washing machine?
when the machin is washing i got a light READY .constant not flushing light. what`s the problem ?
Oct 19, 2010 | Washing Machines
Bosch maxx 1200 has stopped draining half way through the cycle?
Probably a blocked filter.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Have bucket and cloths ready!!!.
Feb 13, 2010 | Bosch Washing Machines
My Bosch Maxx 2000 WFO 2060 is leaking from the bottom. Could it be that a filter somewhere needs to be cleaned? If so where is the filter located?
The filter is usually located at the bottom right front of washer, sometimes behind a removeable cover, or a drop down flap.If you can locate it, then unscrew it anti-clockwise to remove and clean it.
There is also a possibility that there could be a hole or tear in the door seal so check the seal as well.
Hope this is of some help to you .
Dec 07, 2009 | Bosch Washing Machines
I have a Bosch Maxx condenser tumble dryer that wont work.
Have you taken the condenser itself out from the bottom of the machine? Remove the condenser from the bottom door and rotate the clamp tags which secure it in. Slide condenser out (aluminium mutli-finned box assembly) and carefully take it outside. Use a garden hose with lots of water pressure to spray each vent passage carefully to clear lint and dust away. Passages must be cleared in both directions, long ways and cross ways. Cross ways is the problem area and once you finish clearing the air ways you should see daylight through the condenser easily. Reassemble and always clear lint filter in the door /drum area.
Good luck.
Sam
Sep 02, 2009 | Bosch Dryers
Bosch Maxx WFL2860 filter leaking
unplug the power before you do something leak first check and then clean filter, replace some hose available in appliance center.
Jan 03, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Spots of Grey lint left on clothes after washing
Have you cleaned the filter on the front bottom of the machine?
May 11, 2017 | Bosch Washing Machines
Washing Machines Logo
1,471 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
