I need a driver to connect my older PC Concepts, isometric keyboard to my Windows XP laptop using a serial port for attaching. Pad works, but not keys. Thanks. Bill Getz
  • 549 Answers
Here is a website that you can get freeware programs.
There is on that will allow you to find unknown devices on your computer and it will find a driver for it.
If you cannot click the link, go to www.simpleshareware.com
Posted on Apr 24, 2008
Windows XP Boot Up
USB Keyboard take a while to register. Try a serial type keyboard if your system has the Purple serial port on the back.
May 25, 2012 | Dell Inspiron 531s Notebook
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
My old keyboard exchanged for the new one, does not work
You should not need any additional hardware - but you may have to install a driver (software).
If you just bought the keyboard it should have come with an installeation disc. If you don't have that you can go to the following Logitech website and peform the auto scan function (your new keyboard should be attached via USB cable.
This scan will detect the keyboard and tell you if you need any additional drivers installed.
Apr 03, 2010 | Logitech Wireless Access Duo Optical...
Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Jan 22, 2009 | Dynex Wireless Keyboard/Optical Mouse...
Serial keyboard
have you tried just plugging keyboard in..you have usually 2 ext ports one for ext keyboard and one for mouse you can also use usb keyboard/mouse.
if you have a problem with existing keyboard have you tried the on screen keyboard....start,all programs,accessories,accessability,on screen keyboard..when u say serial port do u mean the com port..
for com port you have to assign keyboard and you will need drivers cos not recognised as plug and play
Jan 22, 2009 | Dell Latitude D600 Notebook
Digital concepts digital camera
This camera is compatible with vista and you dont need any software for this camera to work on vista, its plug in play device. When you connect the camera to your computer it should show up as removable disc under my computer. If its not showing up please try connecting the camera into different usb port and make sure your laptop is fully charged.It will work.
Aug 21, 2008 | Digital Concepts 54782/54783 Digital...
Canon BJC 2000 question-1284 to usb
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 05, 2008 | Canon BJC 80 InkJet Printer
SigLite 1x5 Model:T-S460-B (with serial connector)
The problem was not the topaz pad but my laptop. I removed all software which needs the serial port and I finished all not necessary programs which were running in the back but the problem was still alive. Now I asked my administrator for more rights and I changed the name of the port from port "1" to port "3" (port "2" doesn't work). I've got the message "port 3 is already in use" but the pc accepted the exchange of the name. Afterwards I changed the portnumber in the ini.file of the Topaz Software and now it works without any problems... strange, strange.... my five colleagues who are using the same pad on the same type of laptop (Compaq nc 6120) haven't got any problems during installation of the pad.
Thanks for your interest - kind: regards Ben Gun
Apr 06, 2008 | Topaz Systems TOPAZ SIG.CAP PAD SIG.LITE...
IOGear 2-port KVM Switch (Keyboard Issue)
I have had the same problem off and on since I bought my Iogear 2-port kvm switch over a year ago. I have a DYNEX wired, multimedia, usb keyboard and a Dynex wired usb mouse. The operating system on my desktop is Windows XP, SP3 and on my laptop it's Windows XP professional.
Yesterday, my keyboard "died" on me about 8 times and each time it requires unplugging the keyboard usb cable from the switch and my laptop, rebooting, then plugging the usbs back in. Really, really frustrating and annoying. I'm not a techno guru, but I got to thinking that maybe the keyboard driver might be the culprit. I decided to go to Control Panel, clicked on Keyboard, then Hardware/Properties/Driver/Update Driver. I clicked on "update driver" and let it find one automatically. It took what seemed like a long time for it to find the driver but it found one. The device name changed to KeyMaestro P2360, the driver updated, and I noticed 2 additional files were added to the System 32 directory.
It's only been a day but so far so good. My keyboard hasn't failed yet since the keyboard driver update. I don't know if this is the solution for you or not, but it seems to be the one for me. I'll know for sure if I can through a few days without it failing again.
Dec 04, 2007 | IOGear GCS632U 2-port KVM Switch
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
