Question about Broan-NuTone QTXN110HL Combination Light Fan Exhaust Fan
I have a Nutone Model QTXN110HL and the heating function has stopped. When I press the heat button all I get is cold air.
  • 12,061 Answers
I would think that the thermal protection fuse may have blown, this is a common event on these units. Either that or the actual Element has gone open circuit. Another common thing.
If you are able to use a multimeter it shouldn't be too hard to troubleshoot and repair your unit, it is a simple continuity problem, check, thermal fuse, if it has one, and check the element, also sometimes the Thermostat faults, this too will only then give Cold Air.providing you can get parts.
it is always my professional opinion, that one should get all things serviced by a professional, get your unit looked at by a qualified person, and ask for a "Quote" before starting any repairs, this way you can make an informed decision as to repair or replace.
below is your info to do with your series of fans. Both should be of interest.
www.build.com/mediabase/specifications/99043414.pdf
www.homedepot.com/.../f6/f6b75692-c8cc-49a7-9ee4-0b181eb85484.pdf
Posted on Jul 31, 2010
Old NuTone 9093n Model replacement.?
Hi -- I just spent a couple of days taking out the old assembly, cleaning all the parts (layers of dust coats) and putting the 9093N back in order to fix the noisy fan. The cold air coming back in is from to the heating and I'd guess the heating element is busted. Yes, you can run it in both airflow modes: ceiling air exhaust and hot air blown to the floor. That said, the noise level on mine hasn't gone down. So I'll look for the replacement assembly. Good luck!
Mar 23, 2013 | Broan-NuTone Dryers
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
The Heater does not heat, the fan blows cold air
Check the heater to see if it's a 120V or 240V. If it's a 240, make sure there is 240 volts at the supply before going any further. If supply voltage is not the problem, it's probably the heating element OR a thermal overload. Take off the cover and see if there is one or more reset button(s) inside. Try pressing the resets. If all else fails, turn off power and use a multimeter to test for continuity across the heating element.
Feb 26, 2011 | Broan-NuTone N-9192NT Wall Heater Heater
We're renting an apartment in Cairo, Egypt, in which there's a Carrier air conditioner/heater Model 282601 with a remote control. No instructions. We would like to know how to use it properly. At the...
Power on first. Then, in remote, press on/off button. Press mode button still cool or heat symbol displayed (whichever mode you want). If cool, set 23 degree and if u need heat set 30.And wait for 3 minutes to function compressor.
Dec 16, 2010 | Heating & Cooling
When heat on it makes a clicking sound then blows cold then clicks again then blows heat
Yah! I think you pressed mode button. If you press mode button it shows- Fan,Dry,Cool,Heat and Auto. You stop at your required mode.
Dec 12, 2010 | LG Heat cool Window Air Conditioner
Heater doesn't work
The heater elements often go bad in this model. They are pretty simple to change out. They can be purchased online. The replacement heat elements can be found here:
http://www.google.com/search?q=s97016565&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Nov 07, 2010 | Broan-NuTone QTXN110HL Combination Light...
Problem with Vulcan Powerhouse 145 cental heating unit.
You should have a high limit switch possible on the bloiwer compartment may be man reset or just bad you do not say how old unit is I would temp jump out high limit to test operation then replace asap
Jun 11, 2010 | Broan-NuTone 9965 Coil / Ribbon Heater
Heater doesn't work
You can purchase heating elements for this fan that will solve the problem. This is a fairly new fan model so I would recommend calling Nutone because this model has a three year warranty. They may send you the part you need for free.
Jan 28, 2009 | Broan-NuTone QTXN110HL Fan
Hi i have a cs-w24ekr air conditioner. The problem is it blow's cold air when set to heat even at 28degrees.
you have pressed the mode button on remote until it has said heat aswell? becasue 28 degrees in cool mode will still seem cold unless the mode is also set to heat.
Aug 12, 2008 | Panasonic Heating & Cooling
Dryers Logo
128 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
