Question about Intel D102GGC2 Motherboard
When i start PC; BIOS seting opens and says clear
I have INTELD102GGC2 desktop board.
pentium D processor.
when i start PC; BIOS seting opens and says clear all password.
and after exit bios setting message comes that;
Turn off the power and restart.
then PC takes 5 min to set and start my windows 7.
the jumper position is at 1-2 still how can i get message like jumper position of 2-3?
  • 8 Answers
On top of the above , suggest to reset cmos battery too
Posted on Oct 05, 2017
    Sergeant:
  • Intel Expert
  • 278 Answers
  1. pls read the user manual first to identify which pinds of password jumper to normal position
  2. Reinstall the jumper in a different position. For example, if you removed the jumper from pins 2 and 3, reinstall the jumper over pins 1 and 2.
  3. Replace the computer cover and reconnect the power cable and monitor.
You can now assign a new system and/or setup password. For more password information, refer to the Passwords section of your computer'sservice manual.
Posted on Sep 26, 2017
4 Suggested Answers
  • 45 Answers
SOURCE: turn off power and reinstall the jumper in normal mode position
Try to clean the pins on the board, check the connection inside th jumper. (with multimeter or else). Try to clear the bios .
Posted on Mar 22, 2009
  • 11 Answers
SOURCE: Upgrading CPU on Asus PSBW-LA motherboard
Dealing with OEM PC's can be rather difficult. Most of the specifications on those chips are the same, except the FSB (Front System Bus). The E6300 is 1066MHz and the E6550 is 1333MHz. I don't believe that this is set by jumpers (i'm 95% sure). I would look into BIOS to see if it is an available option to change (though most of the time this setting is set on AUTO). There is a chance that you will need to provide a BIOS update. If you chose to do this be very careful as this is dangerous. Should something interupt this (power outage or something like that) your computer could become useless. Definitely make sure to do a lot of research and preparation before performing an update.
Posted on Mar 25, 2009
SOURCE: How to install the jumper in normal mode?
If i am correct, the computer starts up and you see the setup page. It then says that you are supposed to place the jumper in the normal position and It happens every time.
If this is correct, it is telling you that there is a jumper on the motherboard (probably labeled "clear CMOS) and it's set in the incorrect position. There will be three pins. The jumper is installed across two of them. Move the jumper (the little plastic thing) to the other setting: for example, if it's installed on pins 1 and 2, move it to 2 and 3. Give that a try.
The jumper should look something like this: http://tinyurl.com/l8hvqr
Posted on Jun 09, 2009
Hi... i have reset the bios password
it would be best to take it in as it normaly requires opening up the laptop and clearing it with jumpers,dip switches, or a well placed paperclip depending on the relevant laptop or pc that is best left for professionals
Apr 11, 2013 | Samsung - Laptop R480 / Intel Pentium...
Tip
How to reset bios password on basically any pc
This is a password hack but it clears the BIOS such that the next time you start the PC, the CMOS does not ask for any password. Now if you are able to bring the DOS prompt up, then you will be able to change the BIOS setting to the default. To clear the CMOS do the following:
Get DOS prompt and type:
DEBUG hit enter
-o 70 2e hit enter
-o 71 ff hit enter
-q hit enter
exit hit enter
on Jul 24, 2010 | Computers & Internet
Tip
Basic BIOS password crack - works 9.9 times out of ten
DEBUG hit enter
-o 70 2e hit enter
-o 71 ff hit enter
-q hit enter
exit hit enter
Restart the computer. It works on most versions of the AWARD BIOS.
on Jul 16, 2010 | Computers & Internet
Asus desktop bios pass
Hello a bios password is fairly easy to come buy.
Open the case, and locate the cmos battery on the mainboard:
Remove the battery for like 20 min, and insert the battery again.
This will clear the bios password.
But you have to setup the whole bios, boot setings, clock, date, etc, before the pc can run again.
Visit asus here:
http://www.service.asus.com/#!Downloads/c1wax
And enter the mainboard number, or use auto detect to find the mainboard.
This is for downloading the manual, if in doubt setting up the bios.
Good luck
Mar 18, 2013 | ASUS Computers & Internet
(Emachines: intel pentium 4) Everytime i turn on my computer it requests for a system password, and im unable to use my restore cd.
That's known as a BIOS password. If you clear the BIOS, you can possibly avoid asking who set the password, but then you have to be able to set up the BIOS acceptably, about which you can google around for details. Asking around (to others who use the system, in case it's not just you) might let you know something new. Perhaps someone set it from within a utility rather than directly via the BIOS, and perhaps it's a soft error and entering '0' or '00000000' or 'password' or some such default password will avail.
Jan 05, 2011 | Intel Pentium 4 530 3.0GHZ System (SP4S30)...
What is optiplex gx 260 pc's default bios password?my pc ask a bios password,but i never enable bios password.
Here are some important links from which you can get the easy steps and your solution.So please visit the below links and I am sure your problem will be solved
http://www.computerhope.com/issues/ch000235.htm
http://www.computerhope.com/issues/ch000451.htm
http://www.dewassoc.com/support/bios/bios_password.htm
Please rate me if this solution works for you
Thanks......Have a great time
Jun 28, 2010 | Dell OptiPlex GX260 PC Desktop
Bios update for t5226... intel update will not work.. some people say it is locked by emachines. i am trying to put an e8400 in it, but i don't think that the processor is supported by the older bios...
It isn't the fact of the BIOS, it's the motherboard chipset.
The eMachines T5226 uses an Intel 945G.
This chipset only supports processors with up to a 1066MHz FSB.
Supporting Data:
1) eMachines T5226 specifications;
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5226
2) List of Intel Chipsets, and more specifically the Pentium 4/Pentium D/Pentium EE chipsets,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_Chipsets
The Intel 945G is the 12th one down, or last in the list.
Looking across to the right, you can see the Intel processors supported, and the maximum FSB support.
(533/800/1066)
The motherboard's BIOS also won't let you overclock the FSB.
The Intel Core 2 8400 has a 1330MHz FSB,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Wolfdale.22_.2845_nm.29
The Intel 945G also won't support Intel processors with the Wolfdale Core.
Feb 18, 2010 | E-Machines T5226 PC Desktop
How to remove acer aspire 5610z laptop bios password.idont no bios password i need change the bios setings,please help[ me
there is only one way to remove Bios password you need to unhook bios battery lala linda
Jun 15, 2009 | Computers & Internet
CMOS Error 0193
The security device plugs into the left front of the MB as viewed from the front. It is approximately 1.5" x 2 inches in size. they sometimes come loose form the socket when a system is moved. Open the case and see if it is there and loose. If completely gone, then you need to contact your MB supplier for either the device, a new board or a factory reprogram of the board to disable the missing device.
Oct 12, 2008 | IBM NetVista PC Desktop
Forgot password
which if bios u have to clear your bois setings.
for that iopen the case of cpu.
then u see cmos cell put back those cmos cell from its case for 20 minutes then resrt the pc.
set again its original space.
if ur prompt again for password u also set jumper which is nearly that cmos cell.
set in 2-3 position then restrt the pc then go to bios setup
clear your bios password.
then save settings
then again set the jumpoer in its position.,
Sep 29, 2008 | Computers & Internet
Intel D102GGC2 Motherboard Logo
89 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
