Question about Maytag Washing Machines
My neptune washer stops frequently and shows Lr on the readout and will not spin out at all
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Lr means locked rotor, this issue occurs due to locked rotors, you'll need to check the rotor wiring and windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad. A little power surge can damage the boards. Please do rate the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Posted on Jul 31, 2010
Frequent LR code, need complete troubleshooting proc. advanced
LR code is usually caused my the motor and motor control board. if you have 120v to the motor control board and remove the multi pin connector and see if the motor goes in to a 50rpm spin. But more than likely it is those 2 parts. If the tub is noisy or hard to turn in spin motion it may be a bad rear bearing putting strain on the motor also.
Mar 17, 2015 | Maytag Neptune MAH5500B Front Load Washer
It said Lr on screen and stops
LR = Locked Rotor on the motor. Many things can cause this. Please contact me, with more details willing to help all I can.
Apr 12, 2014 | Maytag Neptune MAH5500B Front Load Washer
Yes I just want to know I it's worth fixing this prob. I have a maytag Neptune tl washer model fav6800aww it's starts fine but after 3 minutes it stops on wash cycle an after 5 minutes Lr shows on...
Lr error code is locked rotor. Could be a couple different issues.
Google this phrase and read thru the post ""[FIXED] Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin""
Post in that forum if you want to DIY I do not offer DIY help here any more.
Jul 12, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My washer stops working when there is between 8 to 11 min left in the cycle then gives me a Lr on the digital readout. It never finishes the last spin. I am not sure if this is the model, I do not have...
Hello, Thank You for using FixYa. I will be helping you today.LR means locked rotor. Usually when this happens it needs a new motor or motor conversion kit depending on the model.
Thank You and please rate my answer if it was helpful..
Jun 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
Will not spin cloths dry. Lr Problem
HERE IS a TROUBLE CODE CHART that you can download and SAVE for this to go by. I suggest to save it too for future reference
http://www.applianceaid.com/neptune8.html
May 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
Lr shows during spin cycle and pauses washer
you need to replace the motor and the motor control board,it comes in a kit,call your parts store give them the model number and the first two on the serial.common problem with the neptune,the wire harness that plugs into the motor is strait down,moisture runs down the harness and gets into the connectors,it's around 200 bucks for the kit
Feb 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Fills with water but wont wash or spin
The code LR stands for locked rotor you will need a new motor and motor control kit pretty expensive and only covered under you warrenty for a year!
Aug 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG NEPTUNE LR CODE
LR usually means that the the signal from the board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first.
May 13, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
21 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
