Question about Bulova Watch
U.S. Polo Watch (US8170 on back)trying to keep the light on
Trying to keep the light on. it stays on for a couple of seconds but I'm a nurse in semi dark customer rooms a lot and need to see the dial to check pulse. anyway to keep the light on all the time or at least longer?
  • 2,334 Answers
All watches are preprogrammed for all the functions, so, there is no possibility to make it glow for longer or continuously unless you press and hold the light button or just repeatedly push it again and again. Do not forget that prolonged use of light function will shorten watche's battery life significantly.
Posted on Jul 31, 2010
Taking the back of a Beverly Hills Polo Club Watch # 80485
Take your watch to a jeweler to have it removed undamaged.
Jul 17, 2017 | Beverly Hills Polo Club Watches
My casio protrek 2500t watch is in power saving mode but even after keeping in dark for hours between 10pm and 6 am the display does not go off.Please help.
I own the same PRW-2500-1A (all black).Check if under the hours reading, PS appears.If yes,power saving function is activated.
Normally, Power Saving Function is enabled automatically (if activated) if the watch stays in complete dark for sometime.If after a couple of hours in the dark the watch comes suddenly under bright light,the display goes on immediately.Hour interval (10pm-6am) has nothing to do with Power Saver.
Try the following:
a)Deactivate and reactivate (or vice versa) the PS.
b)Leave the watch in the dark for a couple of hours .Then,still in the dark,try,using a very low power light (just that you can,barely read) to check if display is blank.If not you may have a problem with the light sensor found at the bottom of the display.Will be a very rare case but you have to take the watch to a CASIO authorized service.
Apr 29, 2016 | Casio Watches
BEVERLYHILLS POLO CLUB WATCH MEN
Put a screw driver in the hole on the clasp. It shouls flip up and then you can slide the clasp up and down the watch band.
Dec 26, 2012 | Watches
Hi I have a citizen eco watch and it will not stay with the right time have to keep setting it I havent worn it in a while so could you please tell me whats wrong
Your watch runs on light, you need to leave the watch under a light source for at least 18 hours, then as long as your wearing it, it should keep running if you are exposing it to light. At nighttime for a couple nights leave it under a light, so it has a good charge and keeps running. If this does not work then you need to call Citizen Watch repair at 1-800-321-1023.
Sep 16, 2011 | Citizen Eco-Drive watch
We have a Carriage watch by Timex that's my mom's (she's in a nursing home). The watch wasn't keeping time so my brother replaced the battery. It was running fine, now it's lost time....
A second hand that pulses but does not advance usually indicates one of two problems: (1) a weak battery that provides insufficient power to the tiny motor that advances the second hand; or (2) a bit of dust or grit somewhere in the watch's gear train that is jamming up the works.
Try testing or replacing the battery. If that doesn't work, some watchmakers can try to blow out (using very gentle air puffs, not cans of compressed air) the watch movement and/or put it on a special machine to try to unjam the gears. It is usually does not make economic sense to perform further repairs on a watch of this price range, though it is also possible to replace the entire movement.
May 06, 2011 | Watches
Hi my Guess chronograpah 123503G1 keeps getting stuck. First it appeared that the hand on the small seconds dial face was stuck. The watch wwill not keep time while this was stuck. If I shake the watch...
mcdevito75 here, Sounds like your Guess watch neds some service, cleaning, oil etc. You can check with the repairservice directory right here at fixya, bottom of this page click on repair service directory then watches.
Aug 03, 2010 | Guess 17558L1 17558 Watch for Women
I need a manual for a u.s. polo us8170
go to web page of polo tell them the seriel no on back of watch should be no probs
Jan 06, 2010 | Watches
Citizen Eco Drive second hand stoped working
The Citizen Eco Drive watches use special recharchable batteries.
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types.
Okay, if you say your battery goes bad, or watch does not run okay? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
The seconds hand should run in single second steps, if it takes steps regularly, but every 3 seconds or so, it tries to tell you that its power level is going down. It will be able to continue for one or two days, but you should get it into the sun more often.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life. As long as the watch keeps running I believe it should keep good time. It is quartz anyway. If this is not the case, and a good sunbath does not help, the mechanism could be running heavy, possibly due to overheating the watch; no help there...
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
May 31, 2009 | Citizen Eco-Drive BL5184-56L Wrist Watch
Bulova Watch Logo
155 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
