Question about Kenmore 76602 / 76604 / 76609
My kenmore elite trio is beeping and the temp in
My kenmore elite trio is beeping, 81/82 is flashing in the temp readout and the temp is acually at 45 degrees per my meat thermometer...what do you recommend.
catriver
  • 878 Answers
SOURCE: Kenmore trio 569. Fridge No getting cold Temp is now 81 degrees Freezer ice cold
Mark, check to see if the fan is running in the freezer section. Common problem on these 596's trios. If the fan is running, you might have a defrost problem. If it isn't, your part number for the motor is 67002778. No fan, no cool upstairs...Catriver..post back.
Posted on Mar 04, 2007
  • 958 Answers
SOURCE: Kenmore Elite Trio 795
check the damper controller at the center of the fridge. this regulates the air that is coming from the freezer dependent on the signal from the thermistor of the fridge compartment. that is the other thing to check. check it for rresistance and it should change as you change the temperature of the sensor.
i hope i was able to help;;
Posted on Jun 25, 2008
SOURCE: Kenmore Elite Trio 795.7756 /7757 problem
I had the same problem, freezer full of groceries defrosting or crisper drawer freezing produce. Sears Appliance Repair sent servicemen out twice and both times I was assured the problem was fixed. After freezing produce the third time I insisted they come and get the faulty appliance. The replacement has worked perfectly since day 1. INSIST ON A REPLACEMENT
Posted on Oct 20, 2008
tzweeb
  • 318 Answers
SOURCE: Kenmore Elite Trio Frige...Beeping three times in a row suddenly
this unit has a history of the light circuit failing and it will cause the lights to either stay on or off. if they stay on, it will melt the housing around the upper bulb area. it has a recall and should be covered by sears for no charge. it is the control board failure and has a sticking relay for the light circuit, needs board replaced.
the 3 beeps are the unit thinking it has a door open. turn off the alarm on the door control board and call sears 800 # for repair.
Posted on Dec 28, 2008
  • 531 Answers
SOURCE: kenmore elite trio 24.8 model #596.76603600
may be is the board or or refrigerator door is (ajar)
Posted on Apr 07, 2009
Elite Trio. What caused it to die suddenly after only six years?
I was going to explain a device called a "defrost timer", but I did a search on your fridge and found the following important information for you to check on FIRST!
CPSC Maytag Corporation Announce Recall of Kenmore Elite Brand TRIO Model...
Info on Recalled LG and Kenmore Elite Trio Three Door Refrigerators
Oct 01, 2015 | Kenmore Refrigerators
We have a Kenmore Elite 79577554600 Refrigerator. The temperature display is freaking out. The numbers keep changing, lights flashing on and off, temperature counting down from 44.
It is running in "store-demo" mode. Fancy light-show, and the compressor turns off (bad!)
Hold down the right-most two buttons (Ice and refrigerator temp) for about 5 seconds. I think the right-door needs to be open for this to work, but not sure.
This will activate the fridge once again.
Dec 24, 2010 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge is hot, freezer is working properly
The temp control damper solenoid is frozen closed - or the solenoid itself is failed.
CLICK HERE
for the part
#13 in THIS DIAGRAM
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Trio refrigerator doors will not close properly
call a repair service only a person with hands on capability can help you
Oct 07, 2017 | Kenmore Refrigerators
Temperature control
For the Kenmore, keep pushing the button and it should cycle back to the top of the temperature range.
Sep 04, 2007 | Kenmore 63822 / 63824 Bottom Freezer...
Kenmore 76602 / 76604 / 76609 Logo
48 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
