Question about Weber Genesis E-310 Gas Grill
I put in a new full propane tank tonight, and the grill seems not to be getting any gas. The valve is open and it worked fine last night. Any suggestions?
    Sergeant:
    Champion:
  • 277 Answers
Ericksen,
Pull your burners out. Make sure the gas is off at the tank.
At the bottom of the burners there is a pipe with little doors, If those doors are closed all the way, Open them half way and they usually have a locking screw. tighten screws and put back together.
When doors are closed, only gas is expelled. Without air it is less flameable. You need air and gas to create a fire.
OK
Posted on Jul 31, 2010
The grill is too slow when grilling. It doesn't seem to get hot enough
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Aug 01, 2014 | The Holland Grill HGG421408LP Epic Gas...
We replaced the regulator and the grill still does not have big flame always seem to be on low despite knob adjustment
Jul 30, 2014 | KitchenAid Superba KFRS271TSS Stainless...
Unable to get gas our of 'Blue Rhino" propane
The problem is an easy fix. Replace the current Hose/Regulator Assembly with a new one. They run about $30.00, at home centers and hardware stores that sell grills and accessories.
Once you install the new one and connect it to the gas tank, open the gas tank valve Very Very Slowly (Slow Motion, Slow) until it's fully open. If you don't do it this, the new regulator will lockup.
Hope this helps you & thanks for choosing FixYa.
Aug 25, 2011 | Weber Spirit? E-310 Propane Grill
The line from the gas source seems to be plugged on the weber. the gas does not seem to coming through. The weber worked fine last night.
there is sometimes an automatic shutoff if too much flow is detected. Occasionally when the lines are purged and you open the valve on the tank it will activate this.
  1. turn the tank off
  2. turn the burners on
  3. wait 10 seconds and turn the burners off
  4. open tank valve slowly- listen for a slight ping or click, if this happens that is the shut off activating, try again opening the valve more slowly.
Hope this helps, also make sure tank is full and you didn't leave it on all night. If this helps please rate it
Jul 05, 2011 | Weber Grilling
I have a Dukane Stainless Gas Grill (Five Burners, a Rotisserie and Stove top). It worked fine for three years. Now, I am not able to light more than one burner (of the five). When I go to put the second...
It's possible you may need a new regulator, but usually this problem is due to opening the propane tank valve too fast, which can cause the built-in excess flow valve to check closed to only a trickle. Next time you use the grill, very slowly open the tank valve and see if that solves it. If not, replace the regulator. Douglas
Sep 21, 2010 | Ducane 30400040 Stainless Steel Grill
Grill will not light
If there is no gas check the tank, If the tank is fine look at the regulator. It has to be flat, because of a valve inside. This is a safety device incase of tipover.
Apr 14, 2010 | Jenn-Air JLG7130A
My grill does not seem to be getting gas. I put a new propane tank on and still nothing. It seems to be clogged somewhere? Is this possible. I bought a new tank hose last season could that be bad? The...
Take the tank loose from the grill and open all the burners. Then close the burners and reconnect the tank.
SLOWLY open the tank just a little bit and light the burners with a stick lighter. That's what I do. Those new tans have a safety device in them that locks off the gas if the tank tilted even slightly or the gas valves are opened too fast.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 11, 2010 | Vermont Casting The Extreme VCS5005BI...
Gas not getting to grill
Two things could be wrong. Tank valve could be bad, not allowing gas to flow. Or regulator could be bad not allowing gas to pass. Try taking the tank off and pushing a screwdriver into the end of it with the tank open, if gas doesn't come out tank valve is bad, valve has a spring in it to shut down if starts leaking. If tank valve is good regulator must be bad. I am leaning more towards to the tank valve.
Apr 06, 2010 | Weber Genesis Silver B Grill
My weber gas grill suddenly does not heat up enough. It has been working for two years and suddenly the amount of flame is tooooooo small to cook.
Hello. You may not have enough propane left in the tank for it to work properly, you may not have turned the tank valve to the full open position, or your valve safety device may have kicked in. IF this last item is what happened read on:
To reset the check valve and get back to cooking on your gas barbecue grill, first
  • turn everything off. Turn off the grill, the rotisserie, the side burner and the LP gas cylinder tank.
  • Once everything is turned off disconnect the propane tank from the gas grill regulator by unscrewing it or pulling the quick-release on older or retro-fitted propane cylinders.
  • Now turn the grill on. I know, it is dis-connected from the gas tank but we want to ensure that the pressure in the gas lines or any gas in the burners is released.
  • Leave the grill, side burner, rotisserie, etc on high for a few minutes with the hood open before turning all the valves back to the off position.
  • Make sure. Most gas barbeque grill valves must be pushed in to turn them and if turning is attempted without pushing the knob, they will not turn to the “on” position.
  • With the grill, et al turned off reconnect the propane tank and slowly turn the hand wheel to the open position.
  • Slowly. The trick here is to turn the hand wheel slowly.
When the propane gas tank is new or newly-filled, the gas is full and the OPD is pushing slightly on the top filled area and the gas will want to burst through the valve. Slow it down by turning the valve on slowly and the check valve will reset itself.
Regards, Joe PS please rate my answer. Thank you.
Jan 16, 2010 | Grilling
My grill won't light, and I don't hear gas running
sounds like a problem with tank valve. Try attaching back to grill. Open valve slowly, if you open to fast valve thinks it is leaking and shuts down. If this doesnt work try a differant tank, buy always open slowly.
Jun 12, 2009 | Weber Genesis Silver B Grill
Weber Genesis E-310 Gas Grill Logo
166 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
