Question about Whirlpool Duet GHW9150P Front Load Washer
During the wash cycle the machine stops and
Washer constantly stops during cycle & flashes F 06.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F06 is your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 31, 2010
  • Bert Sobanik
    Bert Sobanik Oct 12, 2014
    and how would I go about checking those connections and identifying the fault components?
Flashing fp on my washing machine and stops half way through cycle please help
"PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Sep 28, 2011 | Whirlpool AWM8143 Front Load Washer
Why does the washer stop during a load and "F 06"
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code
GENE
Sep 09, 2011 | Kenmore HE2 Plus Front Load Washer
After starting the wash cycle, the machine will stop and 06 will flash then F will flash. The washer will not complet the cycle
Hi
Thanks for using FixYa. Error F06 in your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Stops during wash cycle
my cabrio agi washer will stop constantly during the wash and rinse cycle and it will say F51 and dL
Sep 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Stops during rinse cycle
Dear customer,
              We recommend the following when a washer's cycles dont advance..
  1. If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  2. If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  3. If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
For details on how to self test these parts plz refer to http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stopping and flashing F 06 fault
F/06 ---- ERROR IS FOR ----------- Drive Motor Tachometer ErrorThe control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.----------
AND TO SOLVE THIS ---------Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU) --
Check the Drive Motor
Check the MCU
Check the Wire Harness
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing mchine stops during cycle and starts beeping
See if you are overfilling you machine or the load is out of balance. Even try running the machine empty
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Wd12 fault
check the pump filter, located bottom right side of machine, its prob jammed with coins etc
Aug 16, 2008 | Indesit W 123 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
297 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
