Question about Kairak KAI-KRP89S Prep Table 89""L (3)door HL R R ss raised pan chiller wpoly cut brd accepts (12) 13 pans ...
Kairak modle#krp89s condenser fan and comprssor not comin on
Condenser fan & comprssor not comin on .there is 120v
  • Kairak Master
  • 17,130 Answers
It is possible that your main contactor is defective.,This in connected at the compressor motor and can be detached. This is the starter contactor for the motor . Now check the lines of the fan for continuity. If there is voltage coming to the compresor and not working you will check the contactor and then the motor. get help if you are unable but keep this information for getting a good estimate for the work that your technician gives you. Hope you try this out. Good day
Posted on Jul 31, 2010
Water is draining into the house?.where is the drain?
Hello, the unit must be tilted back in the window to prevent the condensate from leaking inside. Some units will have a drain plug on the bottum, while others use the condenser fan to scoop up the condensate and splash the condenser to keep it cooler and evaporate the condensate.
May 29, 2012 | Maytag M3X05F2D Air Conditioner
Sounds like unit is getting power but fan doesnt come on
Confirm with a volt meter that you are getting the required voltage from the condenser fan motor contactor, load side of the contactor,which should be the same contactor as for the compressor. Is the comprssor coming on. If the compresor is coming on and the fan motor is'nt, than the fan motor or the run capcitor for the fan motor has failed.
Jan 26, 2011 | Coleman Mach III Air Conditioner
When i switch a/c on i see a/c light on , but only fan no condition , i test all relay , are working i checked the fuse is ok , but i relase no power drwing to the comprssor . i want know where that wire...
Hi:
The compressor clutch wire goes to the pressure switch , which is often located on the side of the evaporator, or in the line going to the evaporator. When there is enough system pressure, the switch has continuity, and if the system is low or empty, the switch is open, to prevent the compressor from running . If your system is fully charged, you can probably guess the switch is bad, but most likely your AC system is low on refridgerant, and keeping the compressor from running.
hope this helps!
Oct 14, 2010 | 1996 Toyota Land Cruiser
Not cooling, compressor and condensor coil fan not running.
It sounds like you may have bad starting components on your compressor. I would check your condenser fan motor for 120v. Or try to put a small box fan behind the ref blowing directly on the compressor to aid in cooling it. If the compressor kicks in then you know the problem is with your condenser fan motor and not your compressor. If the start components are bad you will usually hear a clicking noise from the compressor every 10-15 mins or so.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore Refrigerators
Kairak cold table not getting cool
Clean the condenser
check the fan motor. and the relay.
The place for parts is www.Partstown.com
HERE is the parts list.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 30, 2009 | Kairak KAI-KRP48R Prep Table 48""L...
My weatherking A/C unit only blows out warm air. The air is no longer cold.
if warm air comes out that usaully means the compressor is not comin on, out side unit,condenser fan may be on makin you think compressor is running. or short in the stat wire has heater running to.
Aug 27, 2009 | Heating & Cooling
Changed compressor relay, compressor comes on for a short time then turns off what might be the problem. side by side frigidaire modle # frs26h5asbo
It could be the condenser coil is dirty , the condenser fan motor burned out or the compresor itself is bad.
Aug 13, 2009 | Frigidaire Refrigerators
Condenser fan will not work
Check to see if you have 220 to unit. May have bad breaker. Only feeding one leg. Rusty
May 23, 2009 | Heating & Cooling
Kairak prep cooler
there are defrost heaters in this unit also the fan that is on the top plate could be resting in water. put the init into a defrost and after all the ice has melted clear the drain line thats by the fan on top. while your are looking check the wireing to the axiel fan there.
Oct 25, 2008 | Frigidaire FRS23KF7AB Side by Side...
Kairak KAI-KRP89S Prep Table 89""L (3)door HL R R ss raised pan chiller wpoly cut brd accepts (12) 13 pans ... Logo
135 people viewed this question
Top Kairak Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
Are you a Kairak Refrigerator Expert? Answer questions, earn points and help others
