Question about HP W22 LCD Monitor
My HP w22 Monitor started to make a crackling sound and than all the sudden turned off, or something. It wont come back on. The computer works just not the monitor. Any ideas on how to fix the problem?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 196 Answers
Try checking your Cable connections to the Monitor to the Computer and from the Monitor to the wall outlet.The crackling sound maybe normal.Most Monitors make that sound.
Posted on Jul 31, 2010
  • Dale VanOrden
    Dale VanOrden Oct 03, 2010
    My W22 monitor did the same thing yesterday. It made a crackling sound and then the screen went black. Everytime you power it down and back on the display comes on for about a 1/2 sec. then goes out. Same with unplugging and re-plugging monitor cable. If I shine a flashlight in the screen i can see the desktop faintly. I have read that it could be the inverter board but how does one tell for sure?
Samsung monitor makes a crackling sound and turns off
just chk all the capacitors...100% fault of capaiter and chk for any ic overheat tooo..
any prob...just. tell me..
Aug 16, 2017 | Samsung 2443BWT-1 Black 24" 5ms Widescreen...
My Neovo E-W22 monitor quit working. I have had it just under 2 years. It is as if it is getting no power. Any ideas?
Make sure the power connector is secure with your monitor and the adapter power light is on as green. If not working at all then just contact with AG Neovo as service.us@agneovo.com for 3 yrs warranty repair. But you probably have to cover the one way shipping only.
Mar 17, 2010 | Neovo AG H-W22 TFT - H-W22 22 inch LCD...
Monitor shows on no picture
its because display ic of your motherboard might be damaged.try fixing it by visiting service centre.
Mar 16, 2010 | HP W22 LCD Monitor
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
My hp w22 monitor turns on 4 about 2 seconds then
w22 monitor connected to what ,my guess the vga cable
is the PC on,? what PC is it, with VGA port
is the PC making sounds, it must, the fans must work
2 to3 in desktoop
1 in the laptop (VGA on rear, most)
test the monitor on a good PC yet,be super easy, why not do that.
the manual is here, read that?
as you can see its 12 years old,, and may have ccfl tubes, bad.
http://h10032.www1.hp.com/ctg/Manual/c00771554
ccfl tubes when 5 to 10 years old fail
turn yellow
black
dim
or stobe
or are good one day not next or hour by hour or minute
a fact.
save all this pain, pick it up go to good PC and test it.
why wait, and even risk PC damage ,guessing as most do untrained.
Jan 20, 2018 | HP 22" Widescreen Flat Panel TFT LCD HD...
HP w22 Monitor display disappears after about 2
bill, if monitor not covered by warranty, the check out YOUTUBE for long 8-12 minute video clips of LCD monitor disassembly or LCD monitor repair to find out what the major cause of your monitors SYMPTOM that you described above. Here is a small hint for you. If you didn't see the displayed data on the BLACK lcd panel with the flashlight "trick" then you would know that the entire "switch-mode-power-supply" was in complete SHUTDOWN mode or even blown the "line-in fuse" for the monitor. Also try a visit to www. ccl-la.com/badcaps.htm and view some of their vids on repair of lcd SMPS/INVERTER supplys and cold-cathode-fluorescent-lamp replacement. They also do the repairs and return shipping. Please rate this on fixya if this response was helpful. Bye for now. 12fixlouie
Oct 25, 2009 | HP W22 LCD Monitor
Screen image appears fuzzy, jumpy and broken up into lines.
gardenman13, I would certainly complain to HP about their w22 monitor!! Find out if the units warranty is still valid and can be swapped-out for a REFURBISHED unit. Your w22 shouldn't be hazy, distorted, or flicker for any reason. My best guess is that it (w22) has problems inside with it's "cold-cathode-fluorescent-lamps" and electronic ballast circuit called an INVERTER circuit, which could also cause the main "switch-mode-power-supply" to go a little NUTS upon STARTUP!! FYI you are dealing with a technology similar to the curlie-Q CFL screw-in light bulbs. Their ballast's are called CONVERTERs (ac to ac) and are cheaper. Your lanps are thinner and straight, hung on rear of your LCD panel. I hope this was informative. Please rate this on fixya. 12fixlouie
Dec 11, 2008 | HP W22 LCD Monitor
HP W22 LCD Monitor Logo
270 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
