Question about Epson PowerLite® Home Cinema HD-400 LCD Projector
My projector shows a purple line at the top - Epson PowerLite® Home Cinema HD-400 LCD Projector
There is a purple area showing up when projector is on.
the dust on the LCD panels ,
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 14, 2014 | Sony Vpl-bw7 3 Lcd Digital Projector
Projector Purple Ghosting
aperently it has to do with converting the analogue signal to digital or the other way around..rca is the cable type..the signal is what you are having issues with..you may need a converter..it may also require going into the setup menu of the tv and make it recognize the signal..
Feb 08, 2014 | Office Equipment & Supplies
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
Thick purple line scrolling up from bottom of screen continually
if it is a uniform pulsating line, then it is the main board or engine. if it is a fuzzy line it is the light tunnel
Apr 26, 2010 | InFocus IN72 Multimedia Projector
Viewsonic projector pj501 - Has purple bloch with
2 issues- the light filter on one of the lcd panels is burnt due to excessive dust and heat. and one of the lcd panels is shot. time to replace the entire optical engine, unless you can get the prism assembly. otherwise, replace the projector. if you do, remember to keep it clean.
Nov 17, 2009 | ViewSonic PJ501 Multimedia Projector
CTX Data Projector - Projects strange star image
GO ON LINE AND TRY TYPING
CTX ULTRAVISION PS-5140 PURPLE STAR IMAGE
I RECIEVE 3 HITS AND THAN A CORRECTION ON THE SPELLING AND TERMNOLOGY AND RECIEVED 180+ MORE HITS
TRY MANY TYPING DIFFERENT QUESTIONGS AND STATEMENTS TO FIND WHAT YOU ARE LOOKING FOR AND ANSWERS YOUR QUESTIONS
ROD
Feb 06, 2009 | CTX UltraVision PS-5140 Multimedia...
Purple band on tv dlp LG
Hi there
This is definitelly not your bulb.
Check if there is any damage to the colourdrum , if not then this is a faulty Mainboard.
Must warn you that LG's Mainboards are very expensive.
Feb 04, 2008 | LG DLP Projector 1400Lum RD-JT30...
Epson PowerLite® Home Cinema HD-400 LCD Projector Logo
350 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
