Question about Hayward Pool & Spa
We don't know how to vaccuum with the Hayward filter
We just rented a house that has a pool with a Hayward Vari-flo filter. We don't know how to use the vaccuum. Can you help us please?
  • 8,404 Answers
Find the hose and the vac head and the pole. Assemble. Put the vac head into the water. Find a water return. Put the hose over the water return to fill the hose with water. Find a skimmer, remove the cover and the basket. Insert the hose into the hole (dont let the water out of the hose after you fill it!!!) With the pump on, run the vac over the bottom of the pool until you have cleaned all of the bottom and the sides as far as you can. There should be a brush there also ... with the pole on the brush head. brusl all the pool - sides and bottom.
Other stuff you should know. You should have a Alk level of about 100 ppm, CL level of about 4 or 5 ppm, pH should be around 7.2 / 7.4. Once a week, you should shock the pool ... put in enough CL to bring the level to 20 ppm. You should have about 80 ppm Cyanuric acid. Dry CL comes with Cyanuric acid, liquid does not. If this is a gunnite pool, your CAL level should be around 300 ppm. If you use salt to make CL, your salt level should be 3200 <>. Dont expect the salt generator to meet all your needs. CL you make needs protecting by the cyanuric acid. The more you run the filters, the clearer the water will be. Backwash or clean carts when pressure goes up 10 lbs over fresh clean start pressure.
I hope this helps you. Thanks for your interest in FixYa.com
Posted on Aug 01, 2010
Hayward vari-flo sp0710xr50 install manual for piping
I don't have a manual but basically the intake of the filter connects to the area around the grids. The inside of all the grids connect through a manifold and pipes to the output port of the filter. The pump output should be piped to the return piping of the pool. If you have a heater it should be connected between the output of the filter to the return piping of the pool. If you have a chlorinator the output of the heater it should be connected through a metal-free check valve, into the chlorinator and then to the return piping of the pool. I hope this helps.
Aug 13, 2011 | Hayward EC-40 DE Pool Filter with pump
I CAN NOT GET PRESSURE TO MY SAND FILTER i KEEP TRYING TO PRIME IT BUT IT HAS NOT WORKED i HAVE A hAYWARD S 240 AND A Vari flo I'm just opening my pool on Aug 7, 10 it always happen when we open the...
There is a air leak somewhere between the pool and the inlet to your pump --- probably the connection going into the pump housing from the pool. Put plumbers putty around the joint. Keep checking until you find the leak and the pump actually draws a suction. The impeller is sound, right? If not, replace it and the seal between the motor and the pump housing.
Aug 08, 2010 | Hayward SAND FILTER, PRO SERIES
No suction from hayward variflow pro series sand filter
Try these tips. I am guessing that one of these is the reason that your pool filter is not working properly. If you try these suggestions and they don't work, let me know and I will trouble shoot with you again.
1. Check skimmer and pump strainer baskets for debris.
2. Check for restrictions in intake and discharge lines.
3. Check for air leak in intake line (indicated by bubbles returning to pool.
4. Backwash your filter.
5. Be sure Vari-Flo valve is set on “Filter” position.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
Glass part that screws on is broke
It is the sight glass. If you would like a quote, contact us at www.arrowpools.net for one.
Jul 11, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward vari flo filtering system
Check to make sure the plumbing is in the correct inlet/outlet on the valve head. Sounds like it's plumbed backwards. Inlet is from the pump, out to pool...
May 10, 2009 | Hayward SAND FILTER, PRO SERIES
Pool & Spa Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
