Question about Whirlpool WTW5550S Top Load Washer
Washer wont consistantly start unless drop lid a couple times.. Thanks Tony
  • Whirlpool Master
  • 43,501 Answers
Your lid switch is bad....
here is the part.....
http://www.repairclinic.com/SSPartDetail.aspx?s=t-WTW5550S-%3d%3di1018522&PartID=1018522
heatman101
Posted on Jul 31, 2010
    Sergeant:
    Champion:
  • 277 Answers
You are losing the lid switch... Replace it and Tell Everyone NO dropping the lid anymore or they will have to replace it
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Washer wont operate even with lid shut. I have to push on lid until it starts.
What happens over time is the lid gets a little bent from use , reason it wont start unless lid is put down is because there is a lid switch that is called a safety switch, you might have to bend down lid some or this: Ok, first check under the lid, there is a peg that goes into the top edge of the washer. That is a switch. The idea between this is that it is a safety feature for mostly kids, so that when the washer is on that high speed spin cycle, that a child does not open up lid and stick there arm or hand in and have it injured. Most washer are designed so that the washer will only spin when the washing machine lid is down. So, of course you have it down, but sometimes the lid might have got a little bent or warped. So first try with lid down pushing down on lid while on spin cycle. If still wont spin, most likely it is that switch that that peg goes into, if you take a knife or flat head screw driver, with lid up on spin cycle and push into that hole with the knife or flat head screw driver and do not here a click when pushing it and releasing it, then you need to replace that switch, it is pretty cheep, normally under 20 bucks and a appliance store and when picking up the part they can tell you exactly how to replace it yourself, it is pretty easy and only takes a few minutes. Hope this helps. Mike
Sep 09, 2011 | Maytag Ensignia 3.3 cu. ft. Top Load...
The spin cycle does not consistently start.
sounds like you may have abad lid switch, not always making contact to tel the unit the lid is closed therefore for safety resons the machine will not spn/ and or drain water.. does it seem to start when you lift and drop the lid assy after checking? you oshould hear a "click" indicating the switch is been made
Apr 23, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
Problem with spin in rinse cycle
Yeah that is a lid switch problem. I have a page I compiled that shows how to fix this easily: HERE
Jan 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=A4910&productCategoryId=0153000&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00002&componentDescription=TOP COVER, CONSOLE & LID SWITCH
May 12, 2009 | Maytag Washing Machines
Washer wont start
If the machine fills with water normally but then just sits there, you might have a bad lid switch - that's the safety interlock that won't let the machine start unless the lid is closed. Check the switch and also make sure the lid engages it when you put the lid down. Of course there could also be a problem with the motor, but first check that switch.
Mar 08, 2009 | Roper Washing Machines
Whirlpool washer wont spin
the whirlpool washer fills up with water and does nothing. I have replaced the lid switch and timer and still have the same problem. Please help me. It is only six months old
Apr 10, 2008 | Washing Machines
Washer will not drain
you need sto check your lid switch , open and close your lid a few times and listen carefully, do you hear a clicking noise?? if not the machine doesnt think the lid is down and wont spin for safety reasons, repalce lid switch
Feb 28, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool WTW5550S Top Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal De
