Question about Refrigerators
Water running in the refrigator area and on to floor top of refrigator has water dripping from it, this is a top freezer with ice and water despenser in the door.
  • Refrigerators Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezerwater running in the refrigator - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jul 31, 2010
Water is dripping from the top of refrig from what appears to be a control unit of some type.. The freezer and icemaker work.
If the water is dripping into the ref. from the freezser chances are you have a clogged drain where the water runs out of when the machine goes into defrost. Take everything out of the freezer and look at the back of the machine and see if you have ice built up. The vents that ru from the freezer to the ref. are loacted in the middle and chances are ice has gotten into them and is thawing and running into the fridge. Unplug the machine, take the back freezer wall off and clear the ice away. I use a screwdriver to tap into the drain hole to clear the ice but you can use hot water as well. Once you see water draining properly down the hole, put it back together and your good to go.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Nov 02, 2010 | KitchenAid KTRP22EM Top Freezer...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a top freezer model and every morning their is a small pool of water in front on the floor. I checked the bottom tray in the back and drip tube and they seem to be ok. I noticed in the door that...
These doors are not water cooled. Is there water in the drip pan? Likely not and the drain is froze over with ice. you will have to remove the rear panel inside the freezer and clean the drain. There is most likely ice under the freezer floor that needs removed also. Take your time and do not damage the styrofoam separator and air channels.
Eric
Aug 27, 2009 | Refrigerators
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Water dripping from freezer when defrost kicks on.
You probably have a plugged drain in the freezer compartment. Open that up and check it. Hope this helps!
Feb 16, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
