Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AWW thermal fuse is replaced but the control panel still shows "18" and will not start
  • 6,784 Answers
HI. Okay, this code is in reference to the main board. There are major circuit issues that concern the logic sector on this particular board. The necessary actions are to replace the main board in your unit. These actions will correct the problem. Click Here to purchase you new replacement board.
Posted on Jul 31, 2010
TRYING TO FIGURE OUT IF I NEED THE CONTROL PANEL OR CONTROL BOARD ON MAYTAH MODEL # MDG5500AWW
you can't get the board anymore,it's to old and the neptune washer that came with this dryer is the machine that put maytag out of bussiness,your better off just replacing the dryer, to many parts for this are unavailable so i wouldn't put a nickle into it.go here,put your model number in and you can look up all the parts on this machine
https://www.searspartsdirect.com/model-number/MDG5500AWW/3048/0151200.html?searchType=modelSearch&q=MDG5500AWW&searchTerm=MDG5500AWW
look at part number 5,you have to keep going down,this is what they do when parts are no longer available they take it out of order and move it down,but if you really want to keep this dryer and i wouldn't in case something else goes and you won't be able to get part you can google who rebuilds the boards,you send the board to them and they rebuild it.hope this helps you out.
Feb 03, 2018 | Dryers
My Maytag Neptune MAH5500B wont start.We thought it was the control board so we change it.And still wont start
Have you checked the thermal fuses? The main cause of dryers not starting is the thermal fuse.
Mar 06, 2015 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune model mdg5500aww gas dryer. the light comes on but it wii not let me program it to start or stop what could be wrong? is there a way to troubleshoot
1) The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
2) Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
it is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3) Timer may be defective
Mar 13, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500AWW dryer won't start. Put in a new control board but still not starting up. Any suggestions what I can try?
Did you check for lint? Did you check the duct fuse?
If that thang had an air flow issue that fuse blow and then dryer don't say nothing mon ami.783c115.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I replaced the thermistor on maytag neptune gas dryer, model #MDG5500AWW.It still will not start .Do I have to reset the control panel first to get it running?
did you forget to plug the door switch back in? or anything else? oh..it didn't start before...ok. you probably should have replaced the thermal fuse..it's white with 2 wires on it.
Jun 10, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune dryer mde5500ayq replaced old motor with new motor starts up first time alright I turn off and it will hesitate to restart. most times it will not restart. Humms then kicks out. I have no...
Compare the wiring connections on both motors. They may be marked. They may be different. Careful examination will determine the start and run wires. Other wires turn on the heat once the motor reaches running speed. The thermal fuse for the motor is internal and unservicable. The hi limit sensor will control the heat, but will not necessarily turn off the motor.
Apr 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer model # mdg5500aww sensor not working is just starts a 37 minutes
How do I lift the top panel of my Maytag Neptune dryer model MDG5500AWW?
Jan 13, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
121 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
