Question about Pyle AMFM CD DET MARINE RADIO R/C
My Pyle PLMRXT33WT marine radio keeps turning itself off.
This marine am fm radio is brand new and turns itself off after a couple of minutes of running. I have checked the ground and voltage and all seems OK.
    Guru:
  • 632 Answers
This could be due to a short in one of the speaker connections or a bad/blown speaker which is shorting out.
Posted on Jul 31, 2010
Why does my 800 keep going off, then back on again, but itself ?
Try a cleaner/lubricant contact spray. Available @ Radio Shack. Pull out and spray into it, re attach knob and turn in off a number of times. Turn all the way. If problem persist your radio may have a loose wire or solder.
Jan 28, 2015 | Grundig Satellit 800 AM/FM/SW Radio
My Jensen MCD 5110 Marine radio acts like the antenna is unplugged. I can't figure out how to remove the radio from it's sleeve to re-plug the antenna jack (if that is the problem)
I don't know much about marine radios. I am a ham radio operator, but they are much the same, if you do not hear any static (with squelch control turned down), then I suspect you are correct about the antenna. It could be the antenna itself, or the coax line to it, or the connection point at the radio or at the antenna. You're stuck without being able to remove it. If you do and find nothing at the radio, you'll need to check the connection at the antenna etc. Good luck.
Nov 21, 2014 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
How to set the time on a pyle plcd11mrkt marine radio?
Click "Download manual or factory spec sheet", save it to your documents folder, and see page 9 here... http://www.rocktheboatmarinestereo.com/html/67460.html
Jul 16, 2014 | Pyle Audio Players & Recorders
Grundig s350, installed new batteries and radio keeps shutting off by itself
When you press the Power/Sleep button the radio turns on and displays a number 90, or some other numbers. This is the play time that the radio will stay on then turns itself off. It could be that yours is configured with a sleep timer set to 01 minute, 10 or 15. You need to set the timer for a longer period. Thus we turn it on by pressing the Power/Sleep button, read the timer length then press again. Keep making short presses: The timer will cycle through all preset sleep timer durations. Select the length you want.
Jun 19, 2011 | Grundig S350 AM/FM/SW Radio
I have a new AM/FM=MPX in-dash marine CD/MP3 Player that i am installing in a boat. I have connected everything and nothing happens. I have checked voltage to the fuse and it is good. I have pressed the...
Have you connected BOTH 12 volt+ connections, one is to keep the memory alive only the other for operation. The boat is negative earth?
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Mar 05, 2011 | Pyle AMFM CD DET MARINE RADIO R/C
Emerson SmartSet CKS3008 clock radio
It just started working, again, all by itself. We can't figure out how or why it did.
Feb 12, 2009 | Emerson Smartset Clock Radio
Pyle AMFM CD DET MARINE RADIO R/C Logo
412 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
