Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Why will not my ice maker dump..the wire arm in down
  • Frigidaire Master
  • 43,501 Answers
Here are some basic tips for ice maker troubleshootingwhy will not my ice maker dump..the wire arm in - 2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jul 31, 2010
Ice maker not filling
Is power cut on to it? If it has wire arm, it should be down. Is it getting water? If not, a determination will have to be made as to whether the ice maker is sending voltage to valve during harvest cycle. If valve is getting voltage, replace valve. If not, replace ice maker. If Ice Maker is getting water but not dumping it, replace maker.
Oct 19, 2017 | Refrigerators
Why does Whirlpool G16FARXXF05 refrigerator not dump the ice?
as I remember them there is a small heater that warms the bottom of the ice maker so the ice is loosened a little perhaps your timer or heater has gone kaput
Jul 20, 2015 | Whirlpool Refrigerators
On off switch for ice maker
The wire arm that travels up ad down when it dumps ice. Lift the arm to the horizontal position and it should stay there. The ice maker is now off. Push the arm back down and the ice maker is on.
Mar 01, 2014 | GE Adora (DSF25KGTBG) Side by Side...
Kenmore 106.55242400 ice maker knocking noise
most likely you need a new ice maker,one thing that could do this is the white arms that spin around when dumping the ice,sometimes one of the arms bend and jam the ice maker and you'll hear that knocking soundthe arm gets bent,the ice cube gets stuck because the arm can't push it out,,it stops the motor from spinning through it's full cycle and damages it but this is just a guess from something i've seen happen but most likely you need a new ice maker,one other i've seen is the metal arm that you can lift up to shut off the ice maker gets knocked out of the hole it slides into.if you pop off the white cover and get a jumper wire and stick it into the h and t holes you can jump start the ice maker.http://appliantology.org/gallery/image/659-manual-harvest-on-a-whirlpool-modular-ice-maker/
Jan 02, 2014 | Whirlpool Refrigerators
Frigidaire FRS6LR5E ice maker won't stop making ice
Ice maker wire signal arm is being held down by some item in the freezer. Move item and release wire signal arm. Any ice cubes that are frozen together over the wire signal arm. the ice rises in the ice bucket and pushes the wire signal arm up and this is what stops ice production as ice is used then arm comes down and starts ice production all over again. if there is nothing holding arm down then you will need to replace ice maker.
Oct 07, 2013 | GE Monogram ZDI15C Automatic Icemaker
The ice maker suddenly stopped making ice. The "arm" is down. Should it be up?
arm down ...Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Refrigerator will not dump ice.
I hate ice makers. Try putting a glass or something to keep the bar from going all the way down.
Apr 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker is dumping ice but arm is not fully going all the way down
Is your Ice bin filling up too much? Frigdaire did have problems with there ice makers, and I belive the new ones come with a arm extention. Your one of the lucky one's and your icemaker still makes ice! I dont know how old your unit is but they were replaceing icemakers under a factory warrenty. I could be wrong but I think they were doing it up to a 5 year old unit.
Jul 15, 2007 | Frigidaire FRS23H7CS Side by Side...
Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Mar 22, 2007 | Whirlpool GD2SHGX Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
832 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
