Question about Samsung SCX 4521F All-In-One Laser Printer
Open heat errors
When I turn on the printer, the printer can not warming up properly, and give me a open heat error.
I tried to turn it off and unplug it, but the problem stills.
printer is scx-4521F.
  • 525 Answers
Clean thermistor of dirt or Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Posted on Jan 21, 2011
Error code c-3421 in bizhub c220
Hi
The following site gives error codes for a wide range of printers and their user guides can be obtained as well.
Error Codes Konica Minolta bizhub C220 Code C3421
Your error comes up as follows:-
Code:- C3421
Description:- Fusing heaters trouble (Heating side)
• Detected temperature of the heating roller thermistor/C does not go up a given range of temperature even after a lapse of given period of time at warm up. • Detected temperature of the heating roller thermistor/C does not reach to a given temperature even after a lapse of given period of time after warm up is completed.
Remedy:- 1 Check the fusing unit for correct installation (whether it is secured in position). 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 6 Change PRCB. 7 Change DCPU.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 05, 2014 | Office Equipment & Supplies
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
I have more than three machine Xerox PE16, One of them give me Error "Open Heat Error" What can i do
OPEN HEAT ERROR (When warming up, it has been lower than 68 °C over 25 sec)
Meaning : Thermister is not connected to main board or contact point is loose at power on.
Solution : Check thermister contact point, Heating Lamp & Thermostat.
Aug 08, 2011 | Xerox WorkCentre PE16 All-In-One Laser...
Error code 6500
"The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you reset your printer - 1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 01, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6500
That error is an error processing on the main logic board, Canon suggests you replace the main logic pcb.
Aug 24, 2009 | Canon Pixma MP450 All-In-One InkJet...
Error code 6500 flashing
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
4. Properly seated
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Thanks
May 03, 2009 | Canon Office Equipment & Supplies
Open heat error
Open heat error is a fuser error. If you have plenty of clearance around the printer and you are still getting this error, it is the fuser.
Mar 24, 2009 | Dell 1600n All-In-One Laser Printer
Error c3921 konica minolta c451 error c3921 not known what to do
C3921: Fusing sensor wire breaks detection (Center of the heating roller)...
• At the warm-up stage, the heating roller
thermistor/3 voltage does not decrease by
predetermined steps (temperature rise)
within a predetermined time.
upper right door.
Check the fusing unit, IHPU, PRCB and
REDB for proper connection and correct or
If that check still give you error code 3921
Change fusing unit
Mar 16, 2009 | Konica Minolta bizhub C450P Laser Printer
FAX ERROR MESSAGE
It sounds like the fuser rollers are not at the proper temperature to work.
They should be inspected by a technician.
Jun 19, 2008 | Xerox WorkCentre M20i All-In-One Laser...
E001
That is a fuser realted issue. Not warming up properly.
Most likely a defective fuser. The over heat has opened, the heat element has gone bad.
Fuser more then likely needs replaced
Jan 15, 2008 | Canon NP 6545 Copier
Samsung SCX 4521F All-In-One Laser Printer Logo
714 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
