Question about Hi-Pro (HP-P401W) (HPP401W) Power Supply
Presario won't start when power is applied to the HD
I have a HIPRO HP-D3057F3R in a Presario. The computer suddenly stopped and the green LED on the front panel started to flash slowly. I removed the power connector to the hard disk and the computer powered up to the point where is needed a boot disk. Reconnecting the HD power connector, I started the computer, which ran the fans for about 1 second, then the internal power shut off and the LED on the front panel started to flash slowly. The HD works if plugged into another computer. Could this be a power supply problem?
  • chris_n_seal Jul 31, 2010
    Replaced the power supply. That fixed the problem.
3 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: The LED on my HIPRO D3057F3R power supply is
Yes, it does.
More than likely Electrolytic Capacitors, have gone bad in the power supply.
Electrolytic Capacitors are used in the Input, and Output stage of the HiPro power supply, as Filters.
In the Input stage they filter the incoming AC voltage.
In the Output stage they filter the rectified AC.
(AC is rectified into DC. The capacitors are filtering DC at this point.
AC = Alternating Current
DC = Direct Current
A flashlight battery is an example of stored DC)
The HiPro power supply you have produces three main voltages. Three voltage Rails.
A.3.3 Volts
B.5 Volts
C.12 Volts
When Electrolytic Capacitors go bad, or are failing, there is a weak voltage rail.
HiPro power supply's are cheaply mad.
1.The wiring is too small. (The gauge of the wire is below standards)
2.The Electrolytic Capacitors are of low quality.
3.The rectifier bridge has cheap diodes, and too small of a heatsink.
I could go on, and on.
When you have a power supply with a weak voltage rail, there is not enough power for the Processor.
1.ALL the lights use less than 1 Watt.
2.EACH fan uses 2 to 3 Watts.
3.A typical Processor can use 55 to 125 Watts!
[Depends on what processor it is.
This is why lights - light, and sometimes fan's will spin, but the computer won't run.
Not enough power for the Processor.
Solution?
Replace the power supply.
Viewing this link,
http://www.pcmarketusa.com/product_view.aspx?product_ID=18498
,you can see the HiPro D3057FR3 power supply has just the usual ATX shape, and size.
The ATX 'Form Factor' power supply, is used in approximately 90 percent of computer towers.
[Form Factor usually denotes towards a motherboard. An ATX form factor motherboard is 9.6 inches by 12 inches. Form Factor means the size, and shape.
The Form Factor designation, has been used towards certain hardware parts in a computer, as well as the computer case, but this is erroneously used. It does make it easier to identify with, though. That's why I used it here]
Point I'm getting to?
1.See if you have another Known, GOOD, ATX power supply to use for a test. Test my statements above before you go out, and buy another power supply.
Do you have another computer that has a good power supply, but may have other issues, that you can borrow the power supply out of, to use for a test?
Another thing. This manufacturer overstates the actual rated Wattage. The actual wattage is more like 70 percent of what is stated.
They state 300 Watts - Maximum, but in reality it is more like 210 Watts.
It is for this reason, and the reason that components used in the above power supply are cheap, that I would recommend buying a different power supply, than buying another HiPro.
(Therefore,.NO, I do not recommend the one in the link above, as a direct replacement)
What power supply that fits your needs would I recommend, that is a decent quality power supply, and won't break the bank?
This one,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4675269&CatId=106
OCZ StealthXStream 400 Watt.
Why?
Because it has 80 percent of the true rated wattage.
320 Watts actual.
Because it is reliable.
Because it has all the power cables you need.
Because it is $28 USD after the rebate.
I'm sticking my neck out recommending a particular power supply here, as this goes against our TOS, but if you have no background in this area, how are you going to know what to look for?
I am not recommending the website. But I have used them repeatedly, and always to my satifaction.
Any questions?
Posted on Nov 27, 2009
SOURCE: Hipro HP-d3057f3r computer power supply broken?
I have the same problem. I found this:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph06788&product=12455#bph06788_section_2
  • Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
  • If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
  • Posted on May 18, 2010
    How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
    HP Notebook PCs - Troubleshooting LED Blink Codes or ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
    HP Notebook PCs - Computer Does Not Start and Emits an ...
    support.hp.com/us-en/document/c01732674
    This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
    HP 6735s won't boot, power LED blinks 7 times - HP ...
    Feb 03, 2016 | HP Computers & Internet
    Hipro hp d3057f3r up to how much can my pc have ram?
    The very best thing to do is to go to crucial.com. They will take a look at your motherboard, and tell you how much more you can add, if any, and will sell you RAM which is compatible with what you already have.
    Apr 11, 2014 | Compaq Computers & Internet
    Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
    Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
    Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
    May 04, 2012 | 1994 Nissan Maxima
    How to re-wire a Compaq Presario SR2150NX Case power Switch
    The plastic front of your desktop computer is the Front Panel.
    The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
    F_PANEL_1
    The Front Panel header contains connections for the Power On switch, Power On LED light, HarDDrive activity LED light, and so on.
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864922&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3339274
    (Look at the motherboard photo. The Front Panel header is at the bottom right. Scroll down for the motherboard illustration )
    There are 9 contact pins.
    4 across the Top row, and 5 across the Bottom row.
    The four pins across the Top row are numbered EVEN.
    From the Left side going towards the Right side;
    Pins 2, 4, 6, and 8. There is NO pin 10, just a blank spot.
    The five pins across the Bottom row are numbered ODD.
    Pins 1, 3, 5, 7, and 9.
    A) Pins 2 and 4 are for the Power On switch
    B) Pins 6 and 8 are for the Power On LED
    (LED is dim when the computer is on? Switch the wires around )
    C) Pins 1 and 3 are for the HarDDrive activity LED
    (LED is dim when the harddrive is operating? Switch the wires around)
    D) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
    How to know which wires are for the Power On switch, Power On LED, and HDD LED?
    Follow the wires into the Front Panel. Remove the Front Panel, and follow them.
    (Need guidance removing the Front Panel post in a Comment )
    For additional questions please post in a Comment.
    Regards,
    joecoolvette
    May 02, 2012 | HP Compaq Presario SR2150NX PC Desktop
    Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
    On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
    Apr 14, 2010 | HP Compaq Presario SR2150NX PC Desktop
    I have a HIPRO HP-305 power supply. The green
    the 4 pin connector is for cpu power. the hipro power supply are not very reliable.
    Jun 14, 2017 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
  • Aug 16, 2009 | Hi-Pro Computers & Internet
    Green led light flashing on 700p proview flat panel and no picture
    I have a similar problem.
    Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
    This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
    Oct 03, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
    Hi-Pro (HP-P401W) (HPP401W) Power Supply Logo
    91 people viewed this question
    Top Hi-Pro Computers & Internet Experts
    Alun Cox
    danielle yancer
    danielle yancer
    Are you a Hi-Pro Computer and Internet Expert? Answer questions, earn points and help others
