Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Freezer alarm Hi, the freezer alarm on my whirlpool american side by side has just come on and the temperature gauge is flashing two dashes
  • 3,083 Answers
Although the unit could have a bad door sensor, I think the unit most likely has a bad temperature sensor or control board. I read that a control board was the problem, with a hole blown in it, so you might check the control board out carefully. I also read that the compressors on these units have a 5 year parts and labor warranty, so if the compressor is running all the time, have it checked out under warranty, if applicable.
Here is what they say to check for the alarm:
1. Alarm buzzer sounds (some models).
  • Freezer temperature is above 20 degrees F.
    Turn Temp-Alarm off until temperature is below 20 degrees F. Be sure freezer is properly leveled, and that door closes freely and gaskets seal properly.
Here are good guidelines for refrigerator repair:
http://www.refrigeratorpro.com/Refrigerator-Repair.html
Posted on Jul 31, 2010
AMERICAN FRIDGE FREEZER ALARM SOUNDS ON FREEZER TEMPATURE SETTING FLASHES TURN OFF AND ON LASTS FOR1 OR 2 HOURS SAME AGAIN
Check freezer temp setting is correct. ( -14*F and 8*F).
If still problem, replace freezer thermostat.
Thanks.
Mar 07, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool FRSS2VAF20/0 . 4years old Freezer compartment Alarm goes on , Ig left for a while and start again the freezer works again but after few hours the alarms come on . The display unit shows two...
Hi, there is a fault in the controller board as it must be tripping off the alarm without the sensor giving the signal. You will need to check the controller board for sorting out, other wise just disconnect the alarm as the freezer is working and the thermostat is controlling the temperature correctly
Feb 24, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Alarm is going off how do I stop it
The best temperature is the midpoint. Typically 3 or 4. The alarm will go off once the temperature goes down to the freezing point.
May 05, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
My american fridge freezers alarm has just gone off and the temperature is reading -- and flashing
is it a side by side if so it is more likely your rear brd that has failed and needs replacing. This brd controls the appliance.It is located in the rear behind the panel at the bottom. Looking from behind it is in the bottom right hand corner
Mar 26, 2010 | Whirlpool Freezers
I have a Whirlpool side by side fridge freezer (brand new only 2 days old) the alarm is going off and the two lines side by side on the freezer side are flashing?
The alarm is set off when the freezer is out of the differential range of the setpoint. In other words, the freezer is still too warm. If you press the alarm button, the sound will stop but the light will stay on. If the unit is working correctly and cooling properly, this light should go out once the cabinet temperature gets close to the setpoint temperature. Hope this helps you.
Mar 04, 2009 | Freezers
Whirlpool Frbb2vaf20 American fridge freezer - Not holding temperature
Get a hold of who ever you purchased it from. It should be under warranty and they should get it working for you.
Jun 22, 2017 | Refrigerators
I have a 6 year old American style fridge freezer. In recent times the freezer alarm has been permanently flashing and sounding periodically. The freezer does not appear as cold as it once was and it's...
Hi thanks for the question. first i would clean all the coils at the back. remove panel and clean . then check to see if the fan in freezer works. then see if any Frost has built up on back wall of freezer. if frost on wall, you have a defrost problem. thanks the appliance doc
Oct 01, 2008 | Whirlpool Refrigerators
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool fridge freezer (american style)
you have a bad control or bad sensor
May 11, 2008 | Freezers
Whirlpool SD20 Freezer Intermittent Temperature Malfunction with Alarm Alert
Apologies, the above two guest comments are mine, not sure what happend!!
Oct 16, 2007 | Whirlpool S20DRSS33 Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
119 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
