Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv dont turn on - Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a vizio e60 tv when you plug in the power the TV does turn on but its blank screen.i think its because of the viziocast but i dont know which module inside the TV controls that. help!!
That sounds like a firmware corruption problem. If you want to change a board, then its the digital board. Personally I dont think its worth it. It's probably going to happen again as Vizio uses substandard parts. Might be worth checking to see if you have any bloated caps since its a known issue. good luck!
Jun 02, 2018 | Vizio Televison & Video
Turn on MTlogic without remote control
Buy one remote control, which have setup codes for your TV brand with its code list.
Jun 02, 2012 | Televison & Video
My Dynex 19" LCD TV
try to disconnect all external devices connected to your LCD TV then try to turn it on again then wait for a minute. if the problem persist you need to get it serviced by Dynex.
hope that helps.
Mar 24, 2011 | Televison & Video
My 27F522T tv turns itself on and changes channels bu itself.
hi
and first of all if u dont want ur tv to turn on by itself when you dont want it to just un plug the cord and when your going to use it just plug it back on.
Sep 16, 2009 | RCA TruFlat 27F520T 27" TV
MY EMERSON TV EWFG2705 DONT TURN ON CAN SOME ONE HELP ME FIX IT?
This is another case of " You need a qualified service technician to diagnose what is not working and replace those defective parts." This suggestion comes from an Electronics Service Technician for more than 40 years. I'm sorry I can help more. G. K.
Apr 06, 2009 | Emerson EWF2703 27" TV
I dont have vchip code fof my used tv
1. Hit the Menu button on the TV. 2. 'INPUT SECRET No.' should appear. 3. Press and hold both VOL (+) and CH DOWN on the TV set simultaneously until the message 'INPUT SECRET No.' disappears. 4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be
Remember do it on the tv not the remote
Nov 14, 2008 | Televison & Video
Tv dont work
check fuse in back of tv behind lower panel right where power cord gose in to tv
Feb 28, 2008 | RCA P61930BL 61" Rear Projection...
When i turn my tv on it makes a surge noise sometimes it turns on and sometimes dont
thats a capacitor problem. you really have to bring that to a service center.
hope this helps.
Jan 14, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
443 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
